Injectors
Old Oct 20, 2011 | 12:12 AM
LS1121's Avatar
Red face Injectors
I'm trying to grasp what I've been told. The "Tuner" told me that he could not complete my tune because when he got the car to 3000 rpm's the fuel pressure went to 33 lbs. The injectors are 28 lb. injectors correct? so what is the problem? Any insight would be Great.
Old Oct 20, 2011 | 12:57 AM
01ssreda4's Avatar
Sounds like a failing fuel pump.........
Old Oct 20, 2011 | 04:31 PM
LS1121's Avatar
Yes that is what he said, but if the injectors are 28 lb. and I have 33 lbs. why could he not complete the tune?
Old Oct 20, 2011 | 04:57 PM
Blk98Vert's Avatar
Because the pump cant hold pressure at high rpm
Old Oct 20, 2011 | 05:04 PM
01ssreda4's Avatar
The injectors need 58 psi to deliver their 29 POUNDS of fuel. Two completely different "pounds".
Old Oct 20, 2011 | 06:07 PM
LS1121's Avatar
OK Thanx, so i need to find some kind of fuel pump so he can finish my tune. What would be an economically priced pump, street driving only.I do not go to the track with my car.Thanx again.
Old Oct 20, 2011 | 07:44 PM
baxsom's Avatar
oem replacement
Old Oct 20, 2011 | 08:09 PM
Blk98Vert's Avatar
Walbro 255
 Michael S. Palmer
Old Oct 21, 2011 | 12:34 PM
LS1121's Avatar
Originally Posted by Blk98Vert
Walbro 255
OK so I did a search and did not find what I was looking for so................................Is there a particular part number for this pump? and is it plug and play for my 98 Z28?
Old Oct 21, 2011 | 02:09 PM
parks450's Avatar
Get a hotwire kit and a racetronix setup. Their one of the best set-ups out their.
Old Oct 21, 2011 | 02:31 PM
01ssreda4's Avatar
That walbro pump is crap. Lots of documented failures. Choose something else.
Old Oct 21, 2011 | 02:54 PM
777's Avatar
777
Get a racetronix fuel pump from one of the vendor's on this site.
98 Fuel Pump
99-02 Fuel Pump
Optional but recommended Hotwire Kit
Old Oct 21, 2011 | 03:32 PM
darkvader0's Avatar
Have to disagree with them being crap. I have the same Walbro 255 pump in all three of my cars now lol. Two of them have been going strong for over 12 years.
My stock Trans Am fuel pump failed a few months ago and I replaced it with the Racetronic/Walbro setup. I recommend them with full confidence.
Old Oct 21, 2011 | 03:39 PM
parks450's Avatar
Not saying walbro us crap completely but their are many documented failures with them. Now on the other hand I have never heard of a racetronix pump failing.
Old Oct 21, 2011 | 03:46 PM
redbird555's Avatar
^You do know the racetronix kit uses a walbro ppump encased in an aluminum sleeve right? OP fuel pumps can be hiit and miss but I woulds till do the racteronix kit as it is a drop in procedure.
Old Oct 21, 2011 | 06:37 PM
LS1121's Avatar
So......what I am getting is Walbro is the best for the money. Some say they are no good but Racetronix is Good and they use the walbro pump. So is there a difference in the pump itself between the 98 which is what I have and lets say 1 99+?
Is there a part # for the 1998?
Old Oct 22, 2011 | 09:23 AM
slt200mph's Avatar
If you are just going to be on the street and not going to the track another option is to replace your stock pump with stock OEM pump replacement pump. You can get a made in the USA OEM replacement pump at rockauto.com for $258 with the wiring harness. Don't beleive all that BS about you have to drop your rear axle or you have to cut a hole in your floor. That is not true. Just drop your exhaust and fuel tank and your there. I just did one two months ago and it took only a hour and twenty minutes to do. I then went on a 5000 mile trip and it worked perfect. Car makes 452/418 and the OEM pump feeds just it fine.
Old Oct 22, 2011 | 11:26 AM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Fuel Pump Module, 99-02 F-Body, Complete
Factory Delphi F99 Fuel Pump Assembly
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Oct 22, 2011 | 11:32 AM
LS1121's Avatar
Great Price but............My Z28 is a 98, will this fit???
Great Video!!!!
Old Oct 22, 2011 | 11:43 AM
Racetronix's Avatar
LS1TECH Sponsor
The one above is for 99-02.
These are for 98 only:
F98 Fuel Pump Assembly - Performance
F98 Fuel Pump Assembly - Factory Upgrade
__________________
>WEB SITE<
