Side exit exhaust
Old Mar 10, 2004 | 04:40 PM
jpbgto's Avatar
Default Side exit exhaust
Anyone have some pics of exhaust that dumps out before the rear tires. And what type of setup they are running. thanks
Jim
Old Mar 10, 2004 | 04:52 PM
slik98z's Avatar
www.ls1sounds.com, check out true duals, that has everything you are looking for.
Old Mar 10, 2004 | 05:04 PM
jpbgto's Avatar
thanks
Old Mar 11, 2004 | 12:31 AM
deviate42's Avatar
Onyx LS1's car:
Old Mar 11, 2004 | 12:35 AM
SSInnovations's Avatar
Is that car lowered? I cant tell,
Old Mar 11, 2004 | 06:17 AM
jpbgto's Avatar
jamie33 can you please tell me what onyx's set-up is. the car looks bad ***. I can only imagine how it sounds. Thanks
Old Mar 11, 2004 | 12:50 PM
slik98z's Avatar
seabassz28, i believe onyx eventually switched to another set up due to groudn clearance issues, the same reason i did as well. i was at stock ride height as well and still coudln't get the ground clearnace id like. if you can get your hands on some squared crushed piping that would benefit you for some ground clearance. its a little easier to create ground clearance with true duals as well from what i saw when i was under the car.
good luck man
Travis
Old Mar 11, 2004 | 01:23 PM
Benjamin Russick's Avatar
silk98: did you guys both already sell that side-exit set-up? I'd like to try it out regardless of ground clearance. If you could direct me to a vendor, that would be cool too... Thanks!
Old Mar 11, 2004 | 01:28 PM
slik98z's Avatar
actually dude, mine got so beat up from smallb umps i just tore it out
slik98z's Avatar
if you want an idea on how to do it i can share that with you pm me
fyi i haven't found any vendors who actually sell it mainly i think because of the groudn clearance issues. but withsome extra time on your hands and resources to get pipes bent and what not, you can do it yourself and do it right. mine only bumped every now and then but every now and then is too much for me so i opted for lt's custom y pipe and hookercatback, but taht side exhaust had its cool factor and it sounded amazing
