Old May 20, 2016, 02:21 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Cooling System Guides
Print Wikipost
Radiator Advice
Old Nov 6, 2011 | 06:51 PM
TransWS6Am's Avatar
I've been running a becool for almost 5 years now, I love it.
Old Nov 7, 2011 | 04:02 PM
navybluephoenix's Avatar
Originally Posted by LPE 403
Definate no-brainer! BeCool here too....
That's just what I was looking for to help me decide haha thanks man!
Originally Posted by djfury05
A better alternative to an expensive aftermarket radiator is to get the Evans Water Pump. The stock water pumps do no flow equal GPM to both side of the motor. The Evans fixes this. Not only more water but equal flow. I will be getting one for sure!
djfury05 thanks so much for all your advice. I just came across that Evans pump the other day and I've never heard of it. It seems like a good piece of equipment, but I won't be getting it until I really need it. My car is not as heavily modded as yours and others on here.
Thanks to everyone who helped me out. I greatly appreciate all your advice and contributing your solutions.
Old Nov 7, 2011 | 05:02 PM
djfury05's Avatar
Yes sir glad to help.. I wouldn't be getting the Evans pump either but I had an issue with my car at the rear cylinders always running leaner so I figure on my new motor a much better water pump and steam port setup should fix my cooling issues.
Old Apr 23, 2012 | 04:43 PM
white01ss's Avatar
(Back from the dead ha ha)
Anybody ever used this radiator?
Spectra Premium CU1485, For Chevy, Pontiac, 3.4, 3.8L
It DOESN'T have the lower driver's side outlet like CU1486 does so it won't interfere with the inlet hat on Procharged cars. I just don't know if there are any other differences that might make it not work.
From what I read the extra outlet goes to the water pump on LT1 V8 cars as the LS1 cars don't need it. They simplified and just make one radiator for LT1 and LS1 cars, but I think the V6 radiator would work just fine in an LS1 car as it has the steam port capped off. I have one sitting in the garage waiting for the lazy owner to put in.
Old Apr 24, 2012 | 03:41 PM
jimmyblue's Avatar
Moderator
I'm happy with the LT1 radiator. I used JB-weld to fill the unused
nipples, in a couple of stages - plastic dam, 1 coat to seal, 1 coat
to fill.
I've heard that you can get sold a skinny core LS1-style rad as
a LT1 replacement, so look at what you're buying for core
thickness. But mine I got real cheap, new, local and right.
Old May 1, 2012 | 01:48 PM
white01ss's Avatar
Thanks for the info Jimmy. Update and good news...
I got the new Spectra Premium CU1485 radiator put in over the weekend. It fits perfectly and IMO is as good quality as the OEM it replaced.
NOTE: Don't get the Ready Rad radiators relabeled as Spectra as they aren't as solid and don't have the required relief cuts in the upper and lower U brace like OEM.
This radiator has the thicker 1 1/4" core and does not have the lower driver's side port that our LS1 cars don't need. For us Procharged LS1 guys that extra port would not clear our air inlet hat so it's a deal breaker. It does have the overflow port, LS1 steam port (comes capped), and radiator hose inlet and outlet ports in the standard locations and sizes.
Initial road tests look promising with water temp staying well below 200* F in 85 weather fully heat soaked. We'll see how it does this summer in 105* heat. I can see no reason why Spectra couldn't specify the CU1485 instead of the CU1486 for our 98-02 LS1 cars.
Dan
Old May 2, 2012 | 11:52 PM
wicknewman's Avatar
Dan
Did you notice any difference in the width? Online measurements show it to be a 1/2" narrower than the CU1486. CU1485 is 24.25" vs the CU1486 24.75" width.
Old May 3, 2012 | 07:57 AM
cajunss's Avatar
Keep us updated on the temps you are seeing. As I'm in TX as well and would like to replace mine as I will be pulling out the stocker anyways to do my cam swap.
Old May 3, 2012 | 10:23 AM
dans94z28's Avatar
I used a v6 radiator and everything was identical and in place. It was also half the cost of the ls1 radiator and ticker by about half inch.
Old May 3, 2012 | 11:28 AM
white01ss's Avatar
Originally Posted by wicknewman
Did you notice any difference in the width from the stock radiator?
Didn't notice any difference. Fan shroud and a/c condenser both fit perfectly. Core thickness was measured 1 1/4" vs 15/16" for the stock one.
I went and checked spectra web site and you are right the measurements say they are different. Maybe there is a mistake in their measurements? I didn't measure them myself, but if it was a whole 1/2" off then my metal ATI radiator support wouldn't have fit as well as it did.
http://ecat.spectrapremium.com
Also, make sure you move the rubber donut isolator from the old radiator to the new one. It's easy to miss.
Dan
Pictures from Spectra's web-site. CU1485 on left, CU1486 on right:
Attached Thumbnails Radiator Advice-cu1485_fro_p04.jpg   Radiator Advice-cu1486_fro_p04.jpg
Old May 3, 2012 | 11:50 AM
wicknewman's Avatar
Thanks for the info, it is much appreciated! I thought that the dimensions might be listed incorrectly. From all the info I have looked at it seems that dimension wise (besides core thickness) all radiators from 93-02 F-bodies are the same for V6 and V8's. The extra sensor holes and water line ports seem to be the only physical differences besides the thinner cores the LS1's came with. Someone please correct me if I am wrong.
Old May 21, 2012 | 10:40 AM
  #32
cajunss's Avatar
What is the part number on the LT1 Radiator everyone is using?
Old May 21, 2012 | 10:45 AM
  #33
BIG_MIKE2005's Avatar
At Advanced its part#: 432399, I'm thinking about grabbing a LT1 radiator for mine as well once I start my auto swap.
Old May 21, 2012 | 11:08 AM
  #34
cajunss's Avatar
Thanks man, Just what I was looking for.
Old May 22, 2012 | 09:33 AM
  #35
white01ss's Avatar
See my post #26 above. The Spectra Premium CU1485 is the one to get. It doesn't have the extra two ports that LS1 cars don't need. Best of luck.
Old May 22, 2012 | 09:44 AM
  #36
cajunss's Avatar
What temps are you getting now that you have it installed?
Old May 23, 2012 | 09:46 AM
  #37
white01ss's Avatar
Staying around 199. I have Fan1 set to come on at 195*, Fan2 @ 204* and it stays right around 200*. Fan1 run on temp is 204 so I know when the car is shut off if it is over 204. Very happy with the new radiator so far.
Old May 23, 2012 | 03:49 PM
  #38
BOBS99SS's Avatar
Captain Double Post
Some of this info is stickey worthy for sure,this was something i didnt know lol
Old May 23, 2012 | 05:54 PM
  #39
BOBS99SS's Avatar
Captain Double Post
Ok i dont really need a new rad but mine has seen better days and with the new engine bay paint job the more new parts the better, does anyone have a pic of a new lt1 rad? Does it come with new side plastic? Also is that part number the exact one i need?
Old Jun 29, 2012 | 01:56 PM
  #40
Hobbyjohn's Avatar
ENGINEERED COOLING PRODUCTS? Anyone ever used on of your car? they say this (All aluminum construction with a heavy duty 2-row core with 1.0" tubes.
- Heavy duty transmission cooler.
- Billet CNC machined filler neck. A new cap is included.
- Fully TIG welded construction with no epoxy.
- Upper hose and lower connection is 1-5/16".
- Overall dimensions are 28" wide x 18-7/8" tall. Core is 24-3/4" wide x 17-3/8" high.
- Does not have low coolant level sensor provisions. On 98-99 cars, you can eliminate the sensor just like the 2000-2002 cars have.) Just curious if its good? For $219. its a steal. Thanks for the info.
