ls1 intake to ls6 intake
Old Nov 5, 2011 | 06:38 PM
bill2129's Avatar
Default ls1 intake to ls6 intake
I have a 98 z28. I'm looking to upgrade from my ls1 intake to the ls6 intake. So what all needs to be done here? When I was on ws6store.com it says for the ls6 intake I will need the coolant pipe kit to convert. Is that all I will need or is there more? I don't wanna find out while doing it I'm missing something. And should it go right in or will other things need to be done? I would like as much info as possible on this. And power gains to. Thank you
Old Nov 5, 2011 | 07:18 PM
3rdCoastPowerSports's Avatar
there are several thread on here that explain the ls1 to ls6 intake swap... type it in the search box... also i believe LS1howto.com has a detailed explanation of the swap
Old Nov 5, 2011 | 09:21 PM
bill2129's Avatar
I already tried before I asked. /=
Old Nov 5, 2011 | 09:24 PM
Darkman's Avatar
https://ls1tech.com/forums/ls4-perfo...ap-sticky.html
Old Nov 5, 2011 | 09:58 PM
VandykeT/A's Avatar
Knock the tabs off the bottom of the LS6 and delete your egr other than taht its pretty straight forward. Oh and watch your oil sensor.
Old Nov 5, 2011 | 10:06 PM
bestlude's Avatar
^^^^ knocking the tabs off the bottom of the LS6 intake allows you to use your old LS1 coolant lines to my understanding. (to save you some money).
I would just buy the LS6 coolant lines and do it the right way..
I did mine about 2 weeks ago
Goodluck and take your time with it
Old Nov 5, 2011 | 10:18 PM
WS6SP33D's Avatar
You dont need the coolant lines unless you just want to switch them. You can either sand or knock off the fins on the bottom of the ls6 and it will fit great. You will need an 8mm and a 10mm socket or wrench and i recommend removing the cowl clips or wearing gloves. Your hands with thank you. Just the coolant lines from the front of the tb, and the cruise and throttle cable bracket. The egr hose from the top front, unplug coil packs and all plugs to injectors to get wiring harness out of the way. Then you will be able to see from there what else need needs to be unhooked/unplugged. then remove the 10 intake bolts (bolts without threads on top) use a piece of tape to hold the rear 4 up until you get the intake out enough to remove. After you slide it out a little (being careful not to break your opsu with the hose on the rear) there are a small vacuum line and another plug on the left rear of the intake left to unplug. After disconnecting those last two things the intake should be free (other than the fi rail) just take the 4 bolts off of it and pull up.
Im sure i left a few things out but thats the gist of it very simple job. Sent from phone.
Old Nov 5, 2011 | 10:34 PM
lemons12's Avatar
I have an intake for sale..
Old Nov 6, 2011 | 12:48 PM
DOG-TWO's Avatar
I would buy the coolant pipe. That's what I did a few weeks back when swapping mine. Be careful with the brittle PCV hose behind the intake and for God's sake DO NOT BREAK THE OIL SENDING UNIT lol. It's kind of an expensive piece, trust me, I'd know. Good luck!
Old Nov 6, 2011 | 01:13 PM
tanks99ls1's Avatar
what intake bro and how much? i helped my buddy swap his out and all we had was all the parts that came off the ls1. except for a few fittings that we bought from auto zone. ill have him post on here and list what he remembers buying. also watch out for your pcv line as we broke his, they are highly sensitive but it was an easy fix... like i said ill have chaos07 post on here or you can pm him.
Old Nov 6, 2011 | 01:18 PM
99 PROBLEMS's Avatar
as a side note: you can not use the stock ls1 coolant lines with a LS6 valley cover! the front line hits the outlet on valley cover.
Old Nov 6, 2011 | 02:56 PM
lemons12's Avatar
Ls6 intake.. Check my threads from my profile page.
Old Nov 6, 2011 | 03:22 PM
tanks99ls1's Avatar
you can but you have to do some rerouting, hence the extra fittings.
Old Nov 6, 2011 | 03:55 PM
torkls1's Avatar
I'd save your money by using a dremel to take the fins off the bottom of the ls6 intake and reuse your ls1 coolant lines.
Old Nov 6, 2011 | 05:04 PM
1gt2nv's Avatar
Use a hammer and a chisel. That's what I did to the one you have and the one I just got!
Old Nov 6, 2011 | 07:18 PM
bill2129's Avatar
Thanks for the reply's. So how about power gains? My car only had a lid and exhaust now. I'm going to get long tubes and a tune also. Is it worth it with all that? And Lemon. Your selling a ls6 intake? How much??
Old Nov 6, 2011 | 07:49 PM
NOTFAST's Avatar
Disconnect line from break boost to intake at the back of the intake, not just at the brake booster. Makes saving the oil pressure sensor a little easier. I learned this the expensive way LOL
Old Nov 6, 2011 | 09:34 PM
bill2129's Avatar
Anyone know of the gains. Like I said im only lid and exhaust. For now.
Old Nov 6, 2011 | 09:37 PM
disc0monkey's Avatar
I couldn't feel a difference in power, dunno why
Old Nov 6, 2011 | 09:45 PM
senicalj4579's Avatar
Thats what I did on my old 98z28. Hammer and chisel it and the stuff will literally break off in a couple mins.
