centerbolt valvecovers?
Old Nov 7, 2011 | 11:04 PM
2manytoyz's Avatar
Default centerbolt valvecovers?
so i have a 98 and just got some 243 heads,it just dawned on me,ima need valvecovers...
Whats the best ones to get?will i need brackets for my coils?I need bolts to right?
what else am i missing,also is there a nice affordable aftermarket cover?
Old Nov 8, 2011 | 12:49 AM
99Bluz28's Avatar
IMO, Check the classified sections.
valve covers
https://ls1tech.com/forums/parts-cla...-y-blocks.html
coil mounts
https://ls1tech.com/forums/parts-cla...ome-parts.html
Old Nov 8, 2011 | 01:19 AM
01ssreda4's Avatar
Nice aftermarket valve covers seem to be fairly pricey. I'm not sure I would trust the cheap ebay china covers honestly. Stock covers would likely be your best bet, and yeah you are gonna need new coil brackets that mate up properly.
Old Nov 8, 2011 | 01:37 AM
lemons12's Avatar
Decent aftermarket covers start around 350-400$ and up.
Old Nov 8, 2011 | 02:03 AM
Undertow74's Avatar
The new Holly ones are pretty nice for under $180 a pair. I orderd some last month, still waiting on them...Let you know how it goes since i understood after the fact that they will bolt up with LS3 coils(mounting holes are different) thought they would bolt right up to the LS1 coils, ill see what i have to do to make them work. Worst case scenerio, i relocate the coils to under the cowl.
Old Nov 8, 2011 | 02:46 AM
lemons12's Avatar
Holley have the lines dont they? They make them with no coil mount tabs? Are they taller than stock ls1 covers?
Old Nov 8, 2011 | 09:20 AM
redtan's Avatar
I got some for sale of my GTO, $50 and their yours.
You will need the brackets and the bolts.
Old Nov 8, 2011 | 12:18 PM
Jim85IROC's Avatar
No prices announced yet as far as I know, but Proform has a full line of new LS valve covers out:
http://66.246.133.199/category-exec/...S_Valve_Covers
Old Nov 8, 2011 | 01:44 PM
Fry_'s Avatar
you could probably get valve covers, coils, and brackets off of a truck for a reasonable price from a junk yard. If you get the ones with heat sinks on them you'll have the added bonus of higher output coils. you'd also have to buy a set of truck plug wires they are longer because the coils mount up higher, and I think you need to get then wire harness for the coils off the truck also.
Old Nov 8, 2011 | 03:24 PM
99Bluz28's Avatar
If you want all new parts as a complete kit then, Tick Performance has it.
http://www.tickperformance.com/1999-...8-ls1-engines/
Old Nov 8, 2011 | 04:37 PM
2manytoyz's Avatar
i wonder if i can modify my existing coil bracket to work with the centerbolt style,anyone attempted this?
Old Nov 8, 2011 | 06:46 PM
lemons12's Avatar
If you have a 98 the coils aren't on a bracket, the perimeter covers the coils are mounted directly to the cover.. Meaning you unbolt them one by one. Therefore you have nothing to modify.. When I had my 98 I got some center bolt valve covers off ebay for like 40-45$.
Old Nov 8, 2011 | 06:54 PM
LS1121's Avatar
just buy a set here on the forum and get the brackets or you can get them on Ebay fairly cheap. I bought mine here I think the Valve Covers were $50 and i paid maybe $25 for the brackets. Stick with the GM stuff it's much easier.
Old Nov 8, 2011 | 08:25 PM
Phantom383's Avatar
Can anyone tell me if there is a difference in the Truck covers vs the car valve covers?
Is one taller, different shape???
Old Nov 8, 2011 | 08:52 PM
David Q's Avatar
I have the covers off of a 5.3,they fit exactly like factory ones. The only difference is the PCV, I had To get a fitting from autozone.
