Removing crank pulley?
The bolt is regular right hand thread. It is 24mm, but I believe a 1" socket works fine (maybe 1 1/16", can't remember). Get a breaker bar on it, and give it hell....it should pop loose, then youll be able to unthread it by hand.
To pull the balancer, thread the bolt in almost all the way, then set up the puller so it pushes against the bolt. Pull on the INSIDE of the balancer...there are 3 pads to hook the tool to. If you pull on the outside, it will probably chip. As you pull, you'll need to back the bolt out as you go...you'll get the idea....
Good luck!
Here is a good page with pics that will show you what to do.
http://www.ebbsnflows.cz28.com/photo4.html
Also, if the car is up in the air and the screwdriver is long enough, you might wanna see if you can slide the screwdriver through the driveshaft where the U-Joint is to keep it from spinning... right behind the yoke that goes into the trans...only an idea :-)
any other ideas?
