Typhoon Intake
Old Dec 7, 2011 | 09:21 AM
  #41
themealonwheels's Avatar
NVM, looks like Jimmy Blue did the work on another similar thread:
"At WOT you have no "time over target" to heat the air
in. Even if the manifold is "heat soaked". If you want to
cut down on that, run your fans full time like I do.
The fin surface area of your radiator is about 5000 square
inches. The surface area of the manifold runner is about
25 square inches more or less. I figured up that at 500CFM
your air spends under 5 milliseconds in the runner.
I spent some time tonight pulling heat transfer calcs
off the Interwebs, and it looks like an aluminum runner
of our geometry and 100C (212F, hotter than water
jacket if you're smart) will push 68 watts (yeah) of
heat and raise the air temp 1.9 degrees (yeah) along
its length.
Feel free to check my work."
Nice! I'll check it, but this may be all I needed on the heat soak argument... Thanks Jimmy
Old Dec 14, 2011 | 11:26 PM
  #42
NicB's Avatar
I found a cheap typhoon intake(96mm) for $350. is it worth buying?
Old Dec 15, 2011 | 07:31 AM
  #43
MustangLS's Avatar
The other thing that may or may not be an issue is the weight difference between the two, which is probably 15-20lbs.
Old Dec 20, 2011 | 05:42 PM
  #44
Tappet Head's Avatar
Its up to you in the End bud, so far I have seen no evidence of not to try a typhoon.
