Blowing smoke
Old 12-01-2011, 02:03 PM
lunatikgixxer's Avatar
Default Blowing smoke
This belongs in both internal and external but i chose this section. My car has been blowing some white smoke lately when i make a pass and with the cut out open it will come up through the cabin. My car has also been smelling like gas lately while idling.. I called my tuner he said he can check it out but that might not be until next week so anything i can check up on?
Old 12-02-2011, 11:24 PM
ls1 1990 VN's Avatar
Best bet, just get it checked out.
Old 12-03-2011, 01:53 PM
3rdCoastPowerSports's Avatar
not sure what your mechanical aptitude is and what tools you have, but i would run a leak down test to find out if i have a head gasket leaking and also check the compression while im at it. you said it is white smoke so your problem is water or coolant. As far as the car smelling like gas when idling, could be your tune
