Header Install Question (pic)
Old Mar 13, 2004 | 05:24 PM
SapphireHawk's Avatar
Default Header Install Question (pic)
My car is awaiting its Kooks Long Tube Headers. I have the old exhaust and the AIR system out.
I just finished jacking the car up higher to prepare for the install. From the ground to the bottom of the front bumper is just over 2ft. Is this high enough to install Kooks?
Sorry about the picture, my camera sucks when taking low light pictures.
Old Mar 13, 2004 | 05:28 PM
Brian2001SS's Avatar
That would be high enough for my TTS. Don't know about yours. Glad to see the safety used (ramps and stands)
Old Mar 13, 2004 | 05:30 PM
Broken041's Avatar
When I did my Flowtechs, I needed the minimum of 15" from the bottom of the passenger side tire to the floor. The angle that the headers needed to go in from the bottom required that much in height. I cannot say for Kooks, but I hope that gives you an idea.
Old Mar 13, 2004 | 07:23 PM
cm02WS6's Avatar
I think you will be high enough. My Kooks slid right in.
Old Mar 13, 2004 | 07:29 PM
foff667's Avatar
LS1TECH Sponsor
check my sig for pics of my pacesetter install height it was well over 20inches
Old Mar 13, 2004 | 07:33 PM
TWISTA TA's Avatar
WARNING: BAD TRADER STATUS
I installed kooks lt's with those same jack stands. The front of your car is perfect now get the back just as high. You will need every inch because the drivers side kooks goes in totally vertical. Get some boards underneath those back jack stands. I actually had mine lower in the back at first and I ended up jacking the back up to match the front
Old Mar 13, 2004 | 07:45 PM
DARK AGE 53's Avatar
Please don't take this the wrong way but I would suggest doing something different with how your cars supported, it's not meant to be an insult but I'd hate to see something go bad. JMO
Al
Old Mar 13, 2004 | 08:32 PM
BLASTER's Avatar
I just did my install 2 weeks ago and you are definately high enough.
Couple of things..
1. Place the jack under the K member for safety. The front stands look a little too far back not to have a support in the front as well.
2. Take your time getting those headers in. The passenger side will slide in with someclever rotating but the driver side may require you to grind the K member, remove the Oil filter and possibly the drain bolt. I know I had to.
Good Luck.
 Michael S. Palmer
Old Mar 13, 2004 | 08:36 PM
Ferocity02's Avatar
Thats looks high enough to me. Mine as about half that high for my install, but then again, I was only installing MAC's. I agree with Dark Age, I would put some blocks or ramps under the front tires, just in case. And one more thing to think about, that might be too high, since you will have to work under the hood. My front end was on about 12" of blocks, and I had some trouble getting far back in the engine bay. I had to uss a paint can to stand on so I could get some leverage. I am 5'10" btw. Good luck!
Old Mar 13, 2004 | 08:49 PM
foff667's Avatar
LS1TECH Sponsor
i ended up just ziptieing the headers to the a/c condensor and lowering the car back down a bit with a jackstand under the pass. header to keep it semi supported...since i was doing it on my own this seemed like the best way so i dont think the car is up too high...definitly i agree with the others in supporting the front end a little better.
Old Mar 14, 2004 | 12:01 AM
tonyt123blue's Avatar
did my slps they are known for being long and we only needed 10 inches from the bottom of the tire to the ground if you got that no wor ries.
Old Mar 14, 2004 | 02:13 AM
BLASTER's Avatar
I bungeed mine to the hood latch once I had them in and then lowered the front from the high jack stands onto ramps. This was an adequate height for me reach in to tighten the headers while a buddy held them from below and left us both comfortable with the saftey of the ramps. Once that was done, I torqued them, put the valve covers back on followed by the coil packs, plug cables, and intake and fired it up. I suggest you do the same. Not only is it a good idea to check for leaks around the flanges but gives the exscuse to try out the open headers. Enjoy the rumble.
Old Mar 14, 2004 | 12:49 PM
2001 White Ws6's Avatar
Please place a jack on the front k member for more safety on the front end. That much weight to be that far from any support is just bad.
Old Mar 14, 2004 | 02:33 PM
Allright, I put a jackstand under the K Member. So everyone can stop worrying. Thanks for all of the feedback and the saftey tips.
Old Mar 14, 2004 | 05:35 PM
14u2nv's Avatar
I had to take out my passenger side Grottyohann header last summer because the air tube broke off and I had to get the hole welded closed. I had my SS about that high and it came right out. If I were you though I would get another pair of ramps and plce them under the front tires for your protection. A friend of mine has a 1996 LT4 Vette and he got some railroad ties and cut them down to (16) 2ft long sections and got some 18 inch long spikes to tie them together. He attach two sections together side-by-side and then attached two more to the top but perpendicular to the bottom pair. Along with the spikes to attach the ties together he also used construction adhesive to hold them together. There is no fear with these under all four wheels.
Old Mar 14, 2004 | 06:46 PM
Here's a tip you don't hear much about, place a shop rag into the motor mount opening on both sides. If you drop a bolt or spark plug into the motor mount when removing them you'll understand why I suggest this.
Old Mar 14, 2004 | 08:23 PM
14u2nv's Avatar
Amen to that!
Judas's Avatar
Here's how I did mine. I ended up putting another pallet on front and rear. The good part is you can stand on the pallets and work on the motor side of the install.
Old Mar 15, 2004 | 04:05 AM
I'm not trying to insult you Judas but I've gone to the trouble of finding a link that might help the family of anyone that might use that method, enjoy. www.funeraldepot.com
Old Mar 15, 2004 | 10:53 AM
Judas's Avatar
