Is it safe?
I don't know if I had a faulty thermostat, or if the person before me put a cooler one in.
Cooler running engines will make a bit more power and be more responsive.
The temp gauge will somewhat accurately show the engine's running temperature. It does sweep from low to high. The myth that it only shows low OR high is just that-a myth.
Running a lower than stock thermostat is pointless without tuning the fans to come on at the same temperature.
Running a 160 thermostat will still allow you to have heat inside.
Running a 160 stat and fan start temp will probably NOT keep your engine at 160 degrees due to the real limiting factor in these cars-the radiator. The stock radiator is barely capable of keeping these engines below 200 degrees. The slightly higher capacity LT1 radiator will help a bit but stepping up to the big BeCool radiator will really keep the temps down.
