mid length headers, an acceptable alternative?
Old Dec 11, 2011 | 03:19 PM
boostnut's Avatar
Default mid length headers, an acceptable alternative?
Long story short -
I'm putting a LS1 in a mustang , the dynatech & kooks swap headers are overpriced, I work in a tube bending/fabrication shop and am considering building a prototype set of mid length headers for my swap.
My concern -
What am I giving up by running 1.75" mid lengths vs. 1.75" long tubes? The engine is a stock bore & stroke LS1, 243 heads, LS6 intake, the cam is likely to be the 224/228 on 114 from texas speed (may go to forced induction later).
Will I be sacrificing torque, top end hp, or ???? with the shorter headers? Any input appreciated!
Old Dec 11, 2011 | 03:41 PM
Blk98Vert's Avatar
You will have less hp and torque everywhere, but it won't be a giant difference
Old Dec 11, 2011 | 04:13 PM
SSTYCOON's Avatar
You'll lost some top end power, but I think you'll make good mid range power and torque. I ran mac mid lengths back in the day on my 98 Z , it ran good, trapped 109 at the strip with those headers and intake only
Old Dec 11, 2011 | 04:22 PM
ULTIMATEORANGESS's Avatar
Smile
why cant you fab up some LTs?
Old Dec 11, 2011 | 04:49 PM
boostnut's Avatar
I could but whatever I end up with I'll probably offer for sale to others doing this swap. Just thought the mid lengths are easier to install/remove, cheaper, ..... $600 for a set of long tubes (dynatechs) that aren't even ceramic coated isn't in everyones budget, I may be able to offer an alternative.
Old Dec 11, 2011 | 08:31 PM
INMY01TA's Avatar
I ran Mac mids a while back and the car made damn good power.
Old Dec 11, 2011 | 09:13 PM
boostnut's Avatar
I've done some searches and found that there are a lot of satisfied Mac mid length users. Macs website sucks, any idea what size the primaries & collectors are on the Macs? Also, where do you buy them, I don't see them at summit or jegs.
Old Dec 12, 2011 | 11:50 AM
98F-1camaro's Avatar
Ran the same setup on my 98 before the h/c package and I also was trapping 109mph in an m6 with only a lid. That was an increase of ~3mph from stock
Old Dec 12, 2011 | 12:36 PM
CHADsterss's Avatar
Go to Edelbrock and buy some LTs for $200
Old Dec 12, 2011 | 02:41 PM
boostnut's Avatar
Didn't know edelbrock made long tubes for an LS in a mustang. Got a part #??
Old Dec 12, 2011 | 06:32 PM
INMY01TA's Avatar
I bought mine from Speed Inc ten years ago. They're not on Speed Incs website anymore so I don't know if they still make em anymore. Bassani made LsX mids for our cars too, give them a try.
Old Dec 12, 2011 | 07:36 PM
thedudeZ's Avatar
Didn't pick up doodoo in a heads/cam small shot n20 car going from midlengths to longtubes.
Old Dec 12, 2011 | 11:14 PM
CHADsterss's Avatar
My bad lol I must have skipped that part
Old Dec 13, 2011 | 09:59 AM
redtan's Avatar
I think it's the other way around. You'll lose some low-mid range torque but make similar if not slightly more power up top.
Longer primaries tend to shift the power curve down and shorter primaries move it up.
Old Dec 13, 2011 | 01:26 PM
1989GTA's Avatar
"I think it's the other way around. You'll lose some low-mid range torque but make similar if not slightly more power up top."
That has been my experience with actually back to back dyno tests. Lost some torque down low and virtually no difference in horsepower above peak torque.
Old Dec 13, 2011 | 02:33 PM
boostnut's Avatar
Interesting, not really what I wanted to hear but I appreciate your input. Long tubes are starting to look unavoidable.
Old Dec 13, 2011 | 02:50 PM
redtan's Avatar
You have to ask yourself...is the difference in low end torque (whatever that may be) worth the cost of long tube headers. Given that your engine is still relatively mild (243 heads, baby cam) and the fact that you're going FI later makes me think that a few lb/ft of torque @ 2000-4000rpm is not going to be worth ~$1000 for pimp long tubes.
Old Dec 13, 2011 | 04:56 PM
1989GTA's Avatar
I know for myself and some others we would not mind killing off some low end torque. I am having trouble enough getting the power to the ground.
Old Dec 13, 2011 | 05:56 PM
Sladester2's Avatar
I always heard LT lose low end torque because of the loss of back-pressure and put the horsepower in the higher RPM's.
Old Dec 13, 2011 | 07:46 PM
boostnut's Avatar
Good point, this car will be a driver. May not be a bad sacrifice.
Next question, is there any advantage to making the primaries equal length if I build mid-length headers?
