Halltech Killer Bee™ II C5 is it worth changing to?
Old Dec 14, 2011 | 05:39 PM
bigboy2's Avatar
Default Halltech Killer Bee™ II C5 is it worth changing to?
I have a friend who has one of these systems for sale and I already have a k&n system on my car already and its a 418 ls3 that made 510rwhp unlocked ...I was wondering what yo guys think is it worth it or just keep what I have.... I am trying to get the best bang for the buck and the only thing I see that would be beneficial would be the 102mm inlet and maf sensor that is the ls7 style? any experiences would be appreciated.....
Old Dec 14, 2011 | 06:03 PM
ctd's Avatar
ctd
Are you running out of air? Map reading beginning of run to max power?
What is your Airflow & Frequency under Hi load?
Old Dec 14, 2011 | 06:30 PM
bigboy2's Avatar
I couldnt tell you.... I know it has a 85mm map on it now...I just started with the ls engines and I assume it has enough...just dont know if its worth spending the money on .. the seller says it bad to the bone ...I dont know thats why Im trying to get some feed back....
Old Dec 14, 2011 | 06:50 PM
Blk98Vert's Avatar
I would absolutely upgrade
Old Dec 15, 2011 | 06:51 AM
SweetS10V8's Avatar
Ls7 card style mafs will reads IATs differently. They always tell the PCM that the incoming air is hotter than it really is, when used with older PCMs.
Old Dec 15, 2011 | 07:15 AM
MeentSS02's Avatar
Kleeborp the Moderator™
This is quite true, and the difference when compared to the tables in an LS1 f-body PCM is not linear (granted, this isn't the same application here). HPTuners unlocked the table that deals with this in the f-body PCM, but I lost interest in trying to calibrate it.
Old Dec 15, 2011 | 09:18 AM
bigboy2's Avatar
Is that a good or bad thing???? and is it worth more power?????
Old Dec 15, 2011 | 09:27 AM
MeentSS02's Avatar
Usually not a great thing - the reported temps will be higher, and could put you into areas in various tables where fuel will be added, timing pulled, etc.
Old Dec 15, 2011 | 09:46 AM
bigboy2's Avatar
In other words just keep what I have?
