how to remove pcv hose?
Old Dec 19, 2011 | 06:22 PM
02ws.sik's Avatar
Question how to remove pcv hose?
Found out my pcv hose has a leak in the front by the tb. How do i remove it? I am buy a whole new one from gm parts direct.
Old Dec 19, 2011 | 06:24 PM
sjsingle1's Avatar
that 2 inches of hose can be replaced with 3/8 fuel line......welcome to to club.....ask me how i know......and the bigger problem is that the rest of it is/will crap out also........i recommend a LS6 valley cover conversion
Old Dec 19, 2011 | 06:26 PM
02ws.sik's Avatar
What is that and yes it just the one 2 inch part. The 3/8 fuel line can i buy that from autozone? Does it go over the hose or inside the hose? Thanks Justin
Old Dec 19, 2011 | 06:28 PM
sjsingle1's Avatar
just remove it and replace.....so easy a caveman could do it
Old Dec 19, 2011 | 06:39 PM
02ws.sik's Avatar
Lol so it just unglugs in front and back and the ground? Does the 3/8 fuel line go over the cut or do you take off that part of the hose?
Old Dec 19, 2011 | 08:20 PM
Blk98Vert's Avatar
First rip the old crap off. Buy 4 feet of 3/8s fuel line, a 3/8s plastic T connector, and a truck PCV valve (look up the number for an 03 Silverado). You will need to use some of the hardlines so cut accordingly. I ran one line from the drivers side valve cover to the passenger side head, then a small section from the passenger side cover to the hose coming from the drivers side. Connect them with the T fitting, then run a section of hose to the stock PCV location. The rest is self explanatory. Should run you around 20 bucks if you need a new grommet like I did, if not you should pay around 10
Old Dec 19, 2011 | 08:28 PM
02ws.sik's Avatar
The rest looks fine so can i just do a 2 inch 3/8 fuel line. Do i just take off that small part and slip the 3/8 over?
Old Dec 19, 2011 | 08:34 PM
Blk98Vert's Avatar
Yes you slip the new fuel line over the hard piece.
Old Dec 19, 2011 | 08:38 PM
02ws.sik's Avatar
So just undo it from the intake and slide it on and plug it up? Sorry just want to be sure.
Old Dec 19, 2011 | 08:54 PM
DBShocker's Avatar
yup tats it pretty much plug and play just remove old hose throw it on the ground, maybe stomp on it and throw it away, and then take the new hose and hook it up to the spots u just removed the old hose from and ur done.
Old Dec 19, 2011 | 08:56 PM
02ws.sik's Avatar
Ok so you can just get new fuel hose and plug and play thanks!
