Please help!!!
Old Dec 31, 2011 | 09:08 PM
bluecamaross's Avatar
Default Please help!!!
Sorry, Not sure if this is the correct place for this question.
My car (a 2000 M6 camaro) idles high when you are driving (hot or cold) when you push in the clutch or take it out of gear still rolling until the car slows down.
The car has to be going about 20mph before the idle slows down to about 900rpm. When it's rolling faster than 20mph it stays idled up at about 2000rpm.
Not sure what the deal is! It revs up and comes right back to idle just fine sitting still....
Anybody please help!!!
Old Dec 31, 2011 | 09:29 PM
justin hover's Avatar
You should inspect your throttle body..See if aythings holding it up
Old Dec 31, 2011 | 09:34 PM
The throttle body closes all the way. Its free and smooth. I can run the car sitting still and it idles down as soon as i let off the throttle. The only time it idles high is when the car is rolling over about 20mph.
Old Dec 31, 2011 | 10:15 PM
cobrakillincamaro's Avatar
My car does the samething but intermittently. I think it might have to do with the IAC. Some other people have sugested a vacume leak before.
Old Jan 1, 2012 | 05:27 AM
omarrakeen's Avatar
more info? when did this start? did you install anything lately? new mods or repairs? it could be a vacuum leak, iac, maf or map..any codes yet?
Old Jan 1, 2012 | 08:38 AM
garygnu's Avatar
clean out the IAC,but also check your TPS .
