Which bolt to remove to loosen the motor mount?
Old Mar 16, 2004 | 11:59 AM
Scalpel's Avatar
Default Which bolt to remove to loosen the motor mount?
Do I remove the long bolt that runs parallel to the ground that goes through the metal bracket (that is bolted to the K-Member) and holds the mount itself in position with the metal bracket?
Old Mar 16, 2004 | 12:08 PM
2001 Pewter WS6's Avatar
Restricted User
If you pull that bolt out it will allow you to separate the motor from the K-Member. Make sure you have the motor supported from either on top or the bottom.
Old Mar 16, 2004 | 12:10 PM
Scalpel's Avatar
Ok, that's the one I was trying to get out. My impact (500 ft-lbs) won't break that bolt loose.
Old Mar 16, 2004 | 01:39 PM
onyxxtreme's Avatar
you gotta get someone to hold the nut on the back with a wrench/rachet/breaker or whatever, while you use the impact on the front.....or vice versa
