Which poly motor mount company?
Old Mar 16, 2004 | 09:36 PM
ThaBeaSSt's Avatar
Default Which poly motor mount company?
Doing a k-member and wanted to replace the rubber mounts with poly and wanted to get opinions on what company to go with. Thanks.
Old Mar 16, 2004 | 11:07 PM
Nasty N8's Avatar
Prothane #7-512 I have a set in stock.
Nate
Old Mar 17, 2004 | 06:18 AM
WILWAXU's Avatar
I run the Prothane's.
Old Mar 17, 2004 | 07:06 AM
Ryan K's Avatar
Pathological Modifier
Prothane is the only "direct" replacement. The Energy suspension one is a little too narrow front to back.
Ryan K.
Old Mar 17, 2004 | 07:34 AM
jfm's Avatar
jfm
What is needed to be done to switch from stock mounts to the Prothane? TIA
Old Mar 17, 2004 | 08:21 AM
Humanoid's Avatar
http://www.humanoidms.com/misc.htm
Look at the bottom write up.
Old Mar 17, 2004 | 10:27 AM
Fulton 1's Avatar
Prothanes here too and just to second Ryan's comment - they are a direct replacement. No shimming required like the ES mounts.
Old Mar 17, 2004 | 05:34 PM
jfm's Avatar
jfm
Very good write up,thanks Humanoid.
Old Mar 19, 2004 | 08:00 PM
Fulton 1's Avatar
Hope it helps
