pcv from ground up
i had run breathers before on my older US cars, and never had any issues, and i cant realy say i have any issues w/the breathers now, i can feel a little smell when the car idles, but no moisture in the oil, and no blue smoke
what worrys me though is the pressure in the block, and possible powerloss?
i gave my pcv system to someone else, and my ls1speed valve covers have no connections for pcv hoses,
i've bin thinking of getting a catch can, and make a new pcv system, and as i dont have the old one, i need to do this from ground up,
is it enough to get some caps in the holes the breather where in, and route a hose from them to the catch can, and connect the catch can to the throttle boddy?
any ideas gladly accepted,
IMO, you'll need to drill and tap a hole in the top front or rear of the drivers side valve cover then install a 90* fitting (with 3/8" barb) of your choice, then run a 3/8" ID oil/fuel line hose to your catch-can, then into you intake. Now for you fresh air inlet remove you current breather and replace it with a pvc breather(w/3/8"barb) .I used a Earl's Performance #3434114ERL and I removed the pcv valve(any equivalent breather will work). Now you'll want to run a length of 3/8" ID hose from the TB fresh air outlet and attach to to the 3/8" barb on you new pcv breather.
That's it you're done!
Here's mine but I do have the LS6 valley cover, and I run 2 catch cans.
pm sent.
