$2500 to blow. need some direction
Old Jan 10, 2012 | 09:58 PM
Heavrolet98's Avatar
Default $2500 to blow. need some direction
Hey guys im getting a 00 SS SLP auto car next week. Its pretty much all stock right now except for the slp exhaust system. I have around $2500 to spend to get as much power to the ground as possible. Heads, cam, intake, i need you guys that have the experience and know what combos make the most power to point me in the right direction.
Old Jan 10, 2012 | 10:18 PM
JPH's Avatar
JPH
Headers, camshaft, induction and tune.
Old Jan 10, 2012 | 10:38 PM
blacknyellow's Avatar
Like^^^^
With the cam get new valve springs. Check out tsp's 228r and 224r.
Old Jan 10, 2012 | 10:47 PM
Sladester2's Avatar
^^^^^ cant beat that, unless you want to save more and then upgrade with like a blower or something.
Old Jan 11, 2012 | 08:41 AM
01BlackCamaroSS's Avatar
Your car is an auto. You should go with a stall converter gears and a H/C pacakge that should bring you right around $2500. Doing h/c on a stock stall and gear car will not be as benefical as the same setup on a stall and bigger gear car.
Old Jan 11, 2012 | 08:43 AM
you could get a set of prc 2.5 5.3 heads for a little over 1000 the came stuff should run you around 500 for the cam springs and pushrods, the stall should run you around 600 and the gears about 400. give or take a few dollars on all the prices
Old Jan 11, 2012 | 11:42 AM
Thats about exactly what i was thinking. Prc 2.5 5.3 heads from texas speed fully assembled with .675 lift springs, a MS4 cam, LS6 intake, 3600 or so stall, 4.10 gears and of course a dyno tune. Any ideas on hp numbers with that setup?
Old Jan 11, 2012 | 11:54 AM
just called texas speed and their saying that i can use the MS4 cam with those heads. Not enough valve to piston clearance. Their pointing me towards the PRC 227 heads which would definetly rise my costs. I'm aiming to get atleast 450hp to the ground, If I gotta come up with some more cash thats not really a problem. Keep those ideas rolling guys.
Old Jan 11, 2012 | 01:16 PM
SweetS10V8's Avatar
Send it to me!!
Old Jan 11, 2012 | 01:34 PM
clonedws6's Avatar
Where are you gettin the cam package for 500? Pushrods usually run 109-119 valve springs are usually 200-270 and the cams are usualy 380-400
thats all new though
Old Jan 11, 2012 | 01:56 PM
V68Sweep's Avatar
This sounds like the ticket. I was going to suggest heads/cam as everyone else has, and since you're an auto you'll really need a stall & gearing to really reap all the benefits.
Old Jan 11, 2012 | 02:11 PM
2QUIK4U's Avatar
I would do headers, lid, 3200 stall converter, rear gears, and a tune. H/C would not be the greatest idea without the supporting mods first.
Old Jan 11, 2012 | 02:22 PM
98F-1camaro's Avatar
ok. First off, are you doing the work? If not, you can forget about all that stuff.
If you are doing it yourself, def go with the converter and gears, some longtubes and h/c package.
If your feeling saucy, you can go nitrous. a stock car with a converter and a 125 shot will put you in the 11's.
Old Jan 11, 2012 | 02:57 PM
I am definetly doing all the work myself. I dont pay anybody to do work that I can do myself. I plan on doing heads, cam, intake, stall, gears, and whatever else I might decide to throw in there. I'm just trying to figure out what combos make the best results.
Old Jan 11, 2012 | 03:18 PM
CaMaRo67RS355's Avatar
Personally I would start with
-Bolt ons like full exhaust, cold air, pulley, upgrade to ls6 intake or fast setup if you could get a good deal on one on the forum or something I cant justify paying full price for one
-Cam kit
-Converter
-Nitrous Kit
-Tune
-After this $2500 is gone save up another and buy you a 12 Bolt or 9" because youll need it if you plan on running a sticky tire
-Heads are a waste of $ for a stock bottom end motor IMO
-Youd hit 500 on tire with bolt ons, cam, 100 shot pretty easy
Old Jan 11, 2012 | 03:28 PM
killerwhale's Avatar
you'll definitely be around that power range whith that ^^ set up
Old Jan 11, 2012 | 04:58 PM
You can run a smaller cam instead of the ms4 with the 5.3 heads if I remember correctly there are some people runing the ms3 on these heads. I know I found ot easier for me to set a goal for a et range instead of hp goal. My car put down 398 to the wheels but ran 11.6's consistently at the track.
Old Jan 11, 2012 | 05:31 PM
NBM99SS's Avatar
A bottle and built tranny
Old Jan 11, 2012 | 09:04 PM
garygnu's Avatar
you need a good stall with a big cam .look at a smaller cam with a TSP head/cam pkg ,and get a stall also.also check out a vengeance racing head/cam kit.
Old Jan 11, 2012 | 09:10 PM
DOG-TWO's Avatar
I don't have experience other than some bolt-on stuff but if I were you I would build a strong stalled tranny and rear end and suspension so you'll never have to worry about those things later on when you're getting into the motor. Just an inexperienced opinion lol.
