bbk intake install
Old Jan 20, 2012 | 04:08 PM
conv55's Avatar
Originally Posted by abcdefbody
Thanks for all the replies.This is good info.I think I'll go ahead and order the ls6 valley cover.It seems worth it. conv55 do you remember off hand which bolt hole it was you had to drill out?$200 seems sort of steep for the injector cleaning.Correct me if I'm wrong but I was thinking new stock injectors were some where close to $250.
If you are standing in front of the car its the first bolt hole on the drivers side was off just slightly, also good idea to put some light weight oil around intake holes to help gasket slide when compressed. I was not able to get the coolant tubes to clear under intake so went with LS6 tube.
