bbk intake install
Old Jan 15, 2012 | 03:36 AM
abcdefbody's Avatar
Default bbk intake install
I'm getting close to pulling the trigger on a bbk intake on a basically stock 98 z28.I was wondering if I could get some help putting my parts list together before I get started.I'm trying to figure out all of the little stuff I need to get the job done as well as the stuff "I may as well do while I'm in there." Any help I receive is greatly appreciated.
Old Jan 15, 2012 | 07:19 AM
Anthony Williams's Avatar
It comes fairly complete, just some minor pre assembly I used some permatex spray adhesive to hold the bottom gasket in place, with the old intake off now is a good time to swap in a new oil pressure sender.
Old Jan 15, 2012 | 07:45 AM
transamtom's Avatar
Carb or Brake cleaner and lots of rags(stuff some clean ones in the intake ports) to clean the crud up under the factory intake.
Felpro intake gasket kit
2 Knock sensors(also wire harness possibly)
1 OPSU and OPSU socket to change it.
LS6 steam tube kit(front& rear)
LS6 Valley cover and bolts or about 6ft of 3/8 Neoprene hose to fix PCV system which is probably rotted.
Anti sieze
An inch pound torque wrench.
10mm socket,10mm ratchet wrench.
Bandaids if you have large hands
Old Jan 15, 2012 | 09:19 AM
88gtman's Avatar
When I ordered mine it came with everything I needed. I just recommened going ahead and buying a Oil Pressure Sending Unit. More that likely you will break it taking it off.
Old Jan 15, 2012 | 01:53 PM
abcdefbody's Avatar
Thanks
this is exactly what I was looking for.
I was wondering if I should change to the ls6 valley cover and steam tubes.
What about cleaning the injectors.
Old Jan 17, 2012 | 12:11 AM
abcdefbody's Avatar
Besides having full exhaust the car is basically a stock 98 m6 Z28. I'm wondering if I should use a stock ported and polished throttle body or would I be better off saving up for BBK'S throttle body. And whats the best way to clean injectors?
Old Jan 17, 2012 | 03:53 AM
Blk98Vert's Avatar
Id run a ported stocker for now, you can always sell it. Buy the bigger tb when you upgrade the entire intake tract. Call fuel injector connection, they can sonic clean your injectors and make them perform like new
Old Jan 17, 2012 | 04:08 AM
bww3588's Avatar
I would forgo the bbk and get a used ls6 intake. Just as good, and will have better resale value if you decide to upgrade in the future.
Old Jan 17, 2012 | 12:13 PM
Cosmos's Avatar
He didn't ask about the ls6.
Old Jan 17, 2012 | 02:03 PM
Go On 3's Avatar
summit has a good deal on 85mm throttle bodies, i just bought a polished one for around 220bucks, its a good quality piece, i heard bbk makes the summit brand tb but idk how true that is.
Old Jan 17, 2012 | 08:05 PM
conv55's Avatar
Just remember if you convert to the LS6 valley cover you will have to cut off about 1/2 inch of casting in the valley on your 98 LS1 to make it fit.
Old Jan 19, 2012 | 12:18 AM
abcdefbody's Avatar
IS IT REALLY WORTH THE TROUBLE OF CHANGING TO THE LS6 VALLEY COVER OR SHOULD i JUST REBUILD THE STOCK SYSTEM ? ALSO, ABOUT HOW MUCH DOES IT RUN TO HAVE INJECTORS CLEANED ?
THANKS FOR ALL THE HELP GUYS.
Old Jan 19, 2012 | 02:01 AM
bww3588's Avatar
Only downfall to an ls6 pcv system is the cutting of the block. If your up to that, there is no reason not to switch it. Your Already going to have to change the bolts.
Old Jan 19, 2012 | 02:56 AM
conv55's Avatar
I have a 98 LS1 and switched to the BBK and LS6 valley cover because when I removed the LS1 intake and turned it over oil started running out from years of blowby, now with the LS6 cover I have no blowby, and love the BBK however I did have to drill out one of the bolt holes about 1/16 that did not line up, if you do a search on youtube there is a video on cutting out the casting for the LS6 and injectors usually cost about $25 each to have cleaned (if you remove them and mail out).
Old Jan 20, 2012 | 12:18 AM
abcdefbody's Avatar
Thanks for all the replies.This is good info.I think I'll go ahead and order the ls6 valley cover.It seems worth it. conv55 do you remember off hand which bolt hole it was you had to drill out?$200 seems sort of steep for the injector cleaning.Correct me if I'm wrong but I was thinking new stock injectors were some where close to $250.
Old Jan 20, 2012 | 02:11 AM
bww3588's Avatar
You can buy larger injectors for that price. Just have to have a tune done before you start it up. This would allow you room to grow if you ever decide to cam it
Old Jan 20, 2012 | 09:51 AM
LPTXZ28's Avatar
No need for the ls6 coolant tubes. Use a hammer and lightly tap down the existing one. Use loctite on the screws that hold the bottom plate on. Also the bbk tb gasket does not have the port for the iac cut out so be sure to do that.
Old Jan 20, 2012 | 12:30 PM
abcdefbody's Avatar
Would larger injectors have any negative affects?I am already planning to get the car tuned after this so that shouldn't be an issue.If I cam the motor, which I probably will soon, it will be a fairly small cam.I'm eventually shooting for 375-400rwhp.What #/hr. injectors should I be considering?
Old Jan 20, 2012 | 01:17 PM
baxsom's Avatar
for that hp range,
the Ford SVO 30lb injectors should work great (actualy 36lb at LS1 pressure)
Old Jan 20, 2012 | 01:54 PM
88gtman's Avatar
No need to knock down coolant tubes. Mine installed over the tubes with no problems. Yes, use some blue loctite on each of the screws holding the bottom panel on and you will need to cut out a hole in the TB gasket for the IAC.
