fed up with idle issue (getting worse)
car idles at about 600 in park and in drive but at stop idles at 500 but dips low almost to 450
MAF sensor?
bad idle air controller? or the stock IAC not good for my bigger aftermarket TB? ( this one is what im leaning towards the most)
engine coolant temp sensor ( noticed the wires going into it are bare and exposed and seem to be barely hanging on to the sensor)
or just really really need a tune for the lt install and the air delete
am i correct in my reasoning so far?
lid
ssra
85mm tb
bbk intake
bbk long tubes
3" cutout
ngks and msd wires
AIR delete
front o2 sensors are denso rear o2 are stock from 2001
so you are saying that even though this isnt a whole lot that it can mess with the car?
i do need the cats codes tuned out, and the AIR system tuned out and the rear o2's tuned out as well. if its still real bad after i swap the IAC and OCT then i will tune right away. i was afraid to tune it bcuz it was running so shitty that i would make it a pain in the *** on my tuner
i lost my mind over this lol i had no idea O2s could cause all this smoke, shake and other crap!
