Weiand lingenfelter vs PP Typhoon Intake
All Aluminum ls1 intakes are garbage! The only time I would buy one is if I wanted the ability to pull over, pop my hood and fry an egg on my intake!!!!
Bottom line aluminum intakes weigh more, ruins the cool INtake air temps that LS cars are known for...
I wouldn't take one if you payed me too...whenever I see one on a car it makes me want to puke, why would you want to make your car worse?
It isn't worth it to me. It makes no sense if the LS6, BBK and Typhoon are the same price and the BBK and Typhoon are proven to gain in the high rpms and lose nothing down low to an LS6. Plus the typhoon can be taken to a 102 opening. If you don't like the look get it powdercoated. And as far as weight it is 14lbs heavier than an LS6, no way you will evehand in r feel that. And as stated heat soak is a myth. Don't believe me than try this. Heat your oven to 350 or so and open the door for a few seconds. Now as fast as you can put your hand in and out as fast as you can. Chances are you won't feel a change in temperature. Think air moving at 1000 plus cfm will? Also what about the metal heads on a metal engine? Pretty sure that will affect air temp more. Also the pcm reads IATs from the sensor in the lid and adjusts timing based off that, not the intake manifold
That's total bs, I can vouch those are heat sinks bc I drag race with a guy with near exact same setup only difference is he has a typhoon and I have an ls6...I can tell you beyond a shadow of a doubt that between runs at the strip I can put my face on my intake while you can't even put your fingertip on his without getting burned...also we have the same thermostat and his car runs about 190 and my car never even sees 180...I don't know bout your engine but my ls1 prefers not to have that extra heat on its air charge...
Oh an most importantly he runs a couple tenths slower than me in the quarter and we both a4...maybe his intake is defective lol
![Twak](https://ls1tech.com/forums/images/smilies2/twak.gif)
I'm not saying they have every single part the same obviously I'm just telling you what I've seen....heat sink being an old wife's tale huh I must have been imagining the temp...do I really have to video tape an infrared reading? You guys must have that magic Chinese aluminum lol...that's why all the guys running big cube serious motors run aluminum intakes instead of fast intakes right? You guys believe what you want it makes no difference to me...just stating the obvious...if don't think an aluminum intake motor is running hotter than composite intake then what can I say...now if you never go the track and only do street driving like an old man there will be no problems...just don't go to the track unless you wanna fry some eggs up
#32
Funny you say that because a lot of guys that hardcore race run an aluminum intake...and way to go back on anything you said. Unless its the exact same car it holds no weight. Also who hotlaps their car this isn't the finale of pinks all out or race wars, you will have time to cool down
#33
No, you're an old man if you don't hot lap your car.
#34
I had a feeling you would bring up the sheet metal intake guys which only do it out of sheer need for enormous runners...half you guys have no clue about thermodynamics or fluid flow so believe what you want but a hotter intake means higher iat which means less power....set up a poll on here an ask if you were given the choice of a free typhoon or fast 90 and see what the consensus is...
#38
