Help!!!!
Old Jan 27, 2012 | 09:31 PM
Travu25's Avatar
Default Help!!!!
Okay so I was driving my firebird tonight and i misjudged a speed bump and it pulled off my driver side pipe....so its running with an open header. Its a tsp x-pipe 3'' and the pipes have been clamped on....sooo all I have to do is loosen the clamp and slide it back in and tighten back up? I need someone to help I have to fix this by morning!
Old Jan 27, 2012 | 10:13 PM
LILWS6's Avatar
If they are clamped you should be able to loosen the clamp and slide them back on. Jack it up and take a look make sure nothing else is damaged and reconnect the two pipes as necessary.
Old Jan 28, 2012 | 12:04 AM
Travu25's Avatar
I did it. it took an hour and a half.....will never drive over there again.
