Alternator only kit?
Old Jan 28, 2012 | 01:39 PM
NOVACRAZY2007's Avatar
Default Alternator only kit?
Does any body know where i can get an alt. Only kit for less than $500?
Old Jan 28, 2012 | 01:54 PM
sjsingle1's Avatar
kit? you want to put 1 together?
Old Jan 28, 2012 | 03:01 PM
arthropraxis's Avatar
If you mean a kit to run the alternator without the power steering pump. Some one does make a pulley kit for that. I just put in an idler pulley above the alternator to get better belt wrap on the water pump.
Old Jan 30, 2012 | 10:58 AM
TurboStangJON's Avatar
BMR sells an alternator only bracket that mounts the alternator on the bottom of the drivers side engine block. I don't know what people are saying about belt wrap but to me alternator only means you have an electric water pump and only the alternator needs a belt.
Old Jan 30, 2012 | 12:22 PM
wtf.suv's Avatar
do you happen to know the part number for the idler pulley you used?
Old Jan 30, 2012 | 06:26 PM
It was a factory LS1 pulley bought at NAPA. Check out this link https://ls1tech.com/forums/conversio...lternator.html
Old Jan 30, 2012 | 06:34 PM
FrankSS's Avatar
I have mine in the stock kocation with the stock bracket... Removed the idler pulley snd got a shorter belt. Do a search on here for short belt mod and you can find the shorter belt # to use
