Truck starter question
Old Jan 28, 2012 | 11:00 PM
beyonddisturbed's Avatar
Default Truck starter question
So I am in the middle of running innovative wiring big 3 and kg3 alternator and figured it'd be a good time to put in the truck starter since id have the starter out. id rather lessen the chance of having my block crack. ordered a new 5.3 truck starter off fleabay for 60 bones. got it wired up, and was in the process of mounting it and i can not get it to fit! Has anyone else had this issue? from my reading I'd assumed it be pretty much basic starter swap but just an improved design. now im heated cuz the damn thing will not align properly
it seems to be hitting on the dust cover maybe? the starters are almost exactly the same from what i can tell (truck has larger opening, gears slightly more visible, mounting block difference.) i will try to post a pic for reference later.
appreciate your thoughts and insight gents
thanks, Jay
Old Jan 29, 2012 | 12:31 AM
sjsingle1's Avatar
yep...........need pics
Old Jan 29, 2012 | 02:37 PM
Ok so here are a couple pics
Starters stock on left truck starter on right. body of the starter is smaller for the truck one.
from the side. notice how the gears are farther forward on the truck starter. idk if this matters?
heres what were working with
stock starter held in
from the bottom. holes line up and it is easily mounted.
truck starter in, had to remove o2 to position it in
from the top truck starter. only can get top side (original long mounting block) lined up.
thoughts? is this the wrong starter? i assumed all 5.3 truck starters would work. do the farther forward gears of the truck starter have a play in this or maybe the small lip you can see right above the lower long mounting block catching on the dust cover? appreciate your help before i just stick the f'in stocker back in.
Old Jan 29, 2012 | 07:04 PM
sjsingle1's Avatar
hmmm......are there diff P/Ns for truck starters? cuz i have heard of the swap......i personally have a MSD starter and love it.........it has the 2 long bolts like a truck starter
Old Jan 29, 2012 | 08:29 PM
I dont know if there are different pns. I was hoping someone would know that. I was under the assumption they were all the same. The reason I got the truck one is because I dont want to shell out $200+ for a starter.
Other thoughts folks? Are there different p/ns for the truck starter? Am i missing something obvious?
Old Jan 29, 2012 | 11:40 PM
SApache40's Avatar
Why would your block crack?
Old Jan 30, 2012 | 11:57 PM
Joshua Thompson's Avatar
The small tab on the stock car starter will break, if this happens when the starter torques it will put enough force on the long bolt and tear the outer hole on the block mount.
Old Jan 31, 2012 | 08:17 PM
anyone with some insight? need help gents
Old Jan 31, 2012 | 09:10 PM
butler's Avatar
Sorry I had no issues with the swap. Are the truck starter bolt holes off set? Looks like it in the pics.
Old Feb 1, 2012 | 08:20 PM
Heres what I am talking about with the lips. it doesnt appear that the regular one has these lips which may be catching on the dust cover? anyone post a pic of there starter mounted I would appreciate it. in the truck starter thread there are none that i could find.
also any thoughts on the farther forward gears catching? i wouldnt think this would be an issue
thanks
Old Jun 30, 2012 | 07:00 PM
ls1wallen's Avatar
thanks
I am bumping this. I am having the same problem as in this pic
Old Sep 30, 2014 | 06:07 PM
Bradlyj8Z28's Avatar
No one figured this out?
Old Oct 3, 2014 | 08:39 AM
1 Slow WS6's Avatar
Trim the dust cover if that's in the way
Old Oct 3, 2014 | 08:50 AM
I remember this thread...What a PITA. If I remember correctly I ended up finangling it in. It is a tight fit but works. It was bumping slightly on something above which wouldn't let me push it in squarely.
Old Oct 3, 2014 | 09:06 AM
I used a 2005 Silverado 5.3 starter. I took the dust cover off, mounted it and then cut off only as much as what was keeping the dust cover from going back on.
I had a busted solenoid on my original starter. Cant get it at the parts store but I found a place the rebuilds starters and they sold me one for 50 bucks. Alot cheaper than buying the whole thing. So I have my original starter as a spare, or for sale.
Old Oct 3, 2014 | 04:13 PM
patSS/00's Avatar
I had the same problem trying to install a starter with the 2 long bolts mounting, finally gave up.
You trimmed the dust cover then put it on the starter before you mounted the starter? Or put on the cover after mounting the starter?
Old Oct 3, 2014 | 04:59 PM
The dust cover is held on by 1 bolt. Unbolted and removed. Installed starter and since the plastic was so brittle due to age and heat I just snapped the top off. Then put it on. It goes up on either side just fine and functions just as originally intended.
Old Oct 6, 2014 | 08:43 AM
thunderstruck507's Avatar
I typically leave the dust cover loose until the starter bolts are started.
