Can't get drivers side Hooker LT in
Old Mar 19, 2004 | 09:55 AM
Mike94ZLT1's Avatar
Default Can't get drivers side Hooker LT in
Hey guys, I got my passenger side header in without issue, didnt even have to drop the starter. The drivers side just does not want to go in though. Ideas?
Old Mar 19, 2004 | 10:07 AM
02ArticZ28's Avatar
Remove the steering linkage and it will slide right in.
Old Mar 19, 2004 | 10:28 AM
JeffT's Avatar
You also have to remove the oil diverter (just above the oil filter) for the hookers.
Old Mar 19, 2004 | 08:01 PM
S2002S's Avatar
I recently installed a set of PPC LTs. Had to get the front end up 36" from the front "chin" to the floor. They went in vertically without a hitch.
Old Mar 20, 2004 | 12:18 AM
Mike94ZLT1's Avatar
Is that easy to remove? I really haven't looked at it. Thanks for the replies guys!
Old Mar 20, 2004 | 12:37 AM
Mike K.'s Avatar
yeah its only 2 small bolts that are easy to get to. Also take the steering knuckle off and make sure you got your car as high as possible. The higer it is the more manuevering you can do.
Old Mar 20, 2004 | 10:58 AM
Tranzor's Avatar
Yep, unbolt the steering linkage... a couple of bolts and that driver's side header will slide up to where it needs to be.
Old Mar 20, 2004 | 12:20 PM
Lane's Avatar
The diverter and linkage and it will 'fall' right in.
Two 10mm bolts for the diverter and two 11mm bolts for the linkage. DON'T forget to put the diverter back in - or upside down! Ditto on the steering linkage - lol.
