New to ls1
1. SLP Loudmouth II and SLP flowpack
2. SLP Loudmouth II and some headers (I heard SLP headers weren't any good)
3. SLP Loudmouth II, SLP lid, good air filter, and a dyno tune
most shops will chagre you around 8 hours on labor so do 8 x labor rates and your looking at that number plus 300 for headers
i would just do the SLP flow pack (only SLP product worth buying) and then a cat back exhasut if you can do it urself. those 2 should put you at 700 area
)$700 will make it hard to squeeze in a tune or headers. Like some of the others have said, the SLP Flowpac kit and a catback exhaust will probably put you around $700. Installing an exhaust is not that bad, its the headers that suck and will run you about $250 or $300 just to get them in.
most shop rates around her (MN) charge 85-100 an hour and this is a 5-8 hour job
Yup. The place I went to ask said "$70 and hour and it will be about a 7-8 hour job". I said **** that, I'll just get my lazy *** in gear and do it myself.
the tune will prob put you over 700 but its worth it, do you need a tune with those? no
but a tune does wonder for a car...even a stock car if you have a good tuner
Then later down the road if I want more, I'll go for headers and a 100 shot plate kit and get a touch-up tune at the previously mentioned shop if I like the work they do.
