lingenfelter trg-002 58 conversion box...12v power wire???
if anyone is running this box in their 4th gen, i was wondering which wire that you guys use to power the trigger box...i know all it needs a keyed 12v wire. just wanted to know which wire you guys tap into since i don't have a test light handy.. any help would be great!
You have to tie it into the switch. Has to have constant 12 volts while starting. Only place to work is the key switch. The only thing that sucks about the box is the motor has to turn over before it will sync and start but does work.
