installing oil cooler need advice...
Old Feb 14, 2012 | 01:50 AM
baezi z06's Avatar
Default installing oil cooler need advice...
HI guys
I was thinking of using this small cooler in front of radiator to cool the oil down at the track
we are not seeing much heat here in Iceland but the oil can get very hot after wot runs in my car...
it´s 12" X 9" 6 row and inlet and outlet is 1/2" -8an
my adapter whith thermostad is the same size after i install a fitting
is it to small cooler and will there be to much restriction will it drop the pressure
i´m runnig ported ls6 oil pump and i´m the oil pressure is 50-60 psi when cold 40-45 psi when cruising around
and at idel when hot it goes down to 20-25psi
what do you guys think
thanks
Old Feb 15, 2012 | 01:59 AM
baezi z06's Avatar
Can i use this cooler
Baezi
Old Feb 15, 2012 | 02:10 AM
bww3588's Avatar
Should be alright, however, before you install it, make sure you check the capacity of The cooler and lines and compensate accordingly.
