Texas Speed 1 7/8" & New 1 3/4" Long Tubes Back In Stock With Velocity Spike!!
Thanks guys for the kind words! All the back orders are being filled & we have plenty more ready!
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Let's work as a team here on Tech!
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
I have your 1 7/8" ceramic coated headers that I bought from you guys last year. How much more HP do your new headers with the velocity spike make over your 1 7/8" without the velocity spike? Is it worth swapping over?
I know TSP has an in-house dyno....maybe some numbers on these "spiked" headers vs the standard headers are in order.
IMO, it won't gain much if anything at all.
1 7/8 TSP Velocity spike headers vs 1 7/8 TSP standard headers.
The Scammer Hammer
George Kook Jr:
A better alternative for the racer on a budget is the spike collector. The spike unit is a collector with an actual spike welded into the center of the collector, at a point where the four tubes converge. "The spike guides the flow to the center of the collector and that increases flow," stated Kook. This spike setup is less expensive than a true merge collector, but it offers similar results.
#39
That is the collector that you see kind of neck down than flare back out, it helps scavenge exhaust gases therefore increasing power. It causes a venturi effect in the pipes. They are a pretty expensive option
