is acid dipping an iron block bad?????
im doing a swap into my 95 t/a
i sent the block off to my buddy to be acid dipped
its now on hold
because ive been told that acid dipping an iron block will warp it
is that true?
has anyone ever had that happen?
has anyone ever even heard of that before?
all help is appreciated
thanks
its now on hold
is that true?
thanks
heard of acid dipping. You are not looking for the process
to remove any material other than rust / grease. If it's
going to etch clean iron, you want some other approach.
