No MAF... What coupler
Old Mar 2, 2012 | 12:34 PM
John Deere racer's Avatar
Default No MAF... What coupler
I'm running without out a maf
What to you guys us to connect your lid to tb
I have. 104 lid and 92tb
I'm sure it'll b a bitch to find something to hook those 2 together
Thanks
Pics would help also
Old Mar 2, 2012 | 12:41 PM
zacht's Avatar
im in the process of finding couplers too!
i bought a 4in 45 degree coupler off ebay. i have the same lid as you, but with the 4in maf. its 4in long, its a slight angle going into the tb, so i can cut down the 45 and it will work great!
to get into that lid i think youll need some sort of pipe in there, and then a piee of 4 in coupler hose (ive seen people use straight couplers)
i say find a piece of 4in pipe first...then figure out the coupler.
Old Mar 2, 2012 | 01:08 PM
Thanks
I just realize I posted in the internal section
Old Mar 2, 2012 | 01:25 PM
mark21742's Avatar
4" PVC drain pipe, and 4" fernco rubber fitting for homedepot or Lowes fits perfect
Old Mar 3, 2012 | 07:40 AM
The home depot mod!!!
Old Mar 3, 2012 | 07:53 AM
mark21742's Avatar
Yup, It's quick, easy, and cost under $10
Old Mar 3, 2012 | 09:25 AM
mikh338's Avatar
what about going from a 98mm lid to stock tb? i have no idea what size stock tb is, i put a thread up and i got no help from anyone : (
Old Mar 3, 2012 | 09:48 AM
Intake hoses. Com
Old Mar 3, 2012 | 10:34 PM
cookba's Avatar
^^yep
Old Mar 4, 2012 | 11:35 AM
usafws6's Avatar
104to a 92 is going to be a straight piece of 4.25 in hose. Roughly 7 in long. Fernco hoses look like garbage and have no place on our cars.
Old Mar 4, 2012 | 01:32 PM
mikh338's Avatar
after speaking to the guys at FTP, they said the 98mm lid and 104mm lid are the same size internally, the 104mm is just bigger at the inlet to accept a 100mm maf. im in SD and not running a maf so he said to just go with the 98mm lid. any idea what i would need for a 98mm to connect to STOCK tb? i have no idea what the outside of the stock throttle body is, ive done searches asked several times on here and still nothing
Old Mar 4, 2012 | 11:05 PM
jayfire's Avatar
I just went outside and measured my stock TB on my 02 WS6 and it was 93mm ID (very outer lip) and 100mm OD. Hope this helps.
Old Mar 5, 2012 | 08:13 PM
Just called them today ordered what I needed
They where very help full
The guy actually said is this for a Lsx car?
Then this is what u need...
