Need new water pump
Old Mar 3, 2012 | 03:53 PM
JLoosh's Avatar
Default Need new water pump
My water pump periodically leaks and now there is ( I believe its comming from the water pump) a squeak. So the pump is on its way out and needs changed.
Now I've got a used one but its been sitting for awhile now, and I am afraid after talking to a guy at work that the o-rings are dried out on the inside and not sure if I want to take the time to change that one and have it leak too. And im not sure where to buy new orings for it.
So I was looking at just buying a new ac delco water pump seeing as from what I could find is that is the best bet for a mechanical pump. Would this pump here work as a direct replacement with no issues ACDelco 252-846.
thanks
Old Mar 3, 2012 | 05:59 PM
ULTIMATEORANGESS's Avatar
how much is a stock WP?
Old Mar 3, 2012 | 06:16 PM
JLoosh's Avatar
I think napa here in town has a new WP for 180. I don't waste my time at auto zone any more and I don't really want a remanufactured pump
Old Mar 3, 2012 | 06:25 PM
redbird555's Avatar
My pump went out a couple months back and I ended up going to advance auto (or oreillys) and buying a new pump there and I've had no issues. Its not a rebuilt and looks just like the oem one, now if you you use this code (RAF7JA1101) like I did it also takes 35 bucks off the price of the pump . Mine ended up being just around 100 bucks with antifreeze and such....
Old Mar 3, 2012 | 09:44 PM
Smizmar's Avatar
Rock Auto has a decent price on an ls2 pump. If you decide to swap intake manifolds later the ls2 works better with the FAST intake.
Old Mar 4, 2012 | 12:43 AM
JLoosh's Avatar
Do you know a part number for that?
And is there any differences for the installation like gasket wise or anything?
Old Mar 4, 2012 | 12:48 AM
Smizmar's Avatar
As far as I know, the installation is exactly the same. Almost every parts store now only sells the ls2 style pump for ls1 f-bods. Maybe someone that knows otherwise will chime in.
Old Mar 4, 2012 | 01:02 AM
JLoosh's Avatar
I think I seen that one on amazon for 104 shipped so wouldn't be to bad and I think the new ones come with a thermistat too
