Radiator Issue on 98 Firebird LS1-Help
Old Mar 4, 2012 | 09:23 PM
rbertjr's Avatar
Default Radiator Issue on 98 Firebird LS1-Help
Lately, coolant is leaking out the top of the radiator by the cap. I thought it was the cap and replaced with a new one; but it's still pushing fluid out of the cap. Also, I didn't see any cracks in the radiator which may be causing the problem. The engine temperature is fine and is not overheating when this occurs. The water pump and theromstat were recently replaced, but I had this problem before those fixes.
What could be the problem? Any suggestions would be appreciated. Thanks.
- Rich
Old Mar 4, 2012 | 10:11 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
check the small hose just below the cap, also check the low coolant level sensor and see if it is leaking around it
Old Mar 4, 2012 | 10:16 PM
rbertjr's Avatar
Thanks. I did check the hose previously and it's not leaking there. But I forgot about the sensor; I'll take a look at it tomorrow.
Old Mar 6, 2012 | 06:22 PM
rbertjr's Avatar
Okay, I checked the sensor and that's not it. After about 5-10 minutes idling, fluid started pushing out the cap again. The car is not overheating. Do you think the radiator may be restrictive?
Old Mar 15, 2012 | 08:24 PM
rbertjr's Avatar
Okay, problem solved. The car was originally from New Jersey; when I got it there was alot of corrosion throughout the car. Well, the problem was the reservoir. It was so corroded that coolant was not flowing into and out of it. I replaced the reservoir and the fluid is no longer pushing through the radiator cap.
Old Mar 15, 2012 | 08:57 PM
joecar's Avatar
What exactly was corroded...? Do mean the overflow hose/tube was clogged...?
Old Mar 15, 2012 | 10:59 PM
rbertjr's Avatar
Yes; and there was alot of material inside the reservoir.
