cut my magnaflow tips off
Yes, if you have some 2.5" pipe welded on with turn downs at the bumper it will help with the drone issue. I think you'll be pleased with your set-up then.
My local O'Reilly's sells 3" turn-downs with flared inlets for $12... I would assume you could find 2.5's for a little less
That system has been sold and replaced with a Flowmaster sotl, also with a turn-down. I have dummy tips mounted but without them, you couldnt see the turn-downs from the rear.
This is the only rear pic I have atm. On level ground, the dump is hidden
I have the Magnaflow catback on mines with the 3.5 inch cannon tips, love the way it looks. The tips are large but they sort of roll up against the bumper perfectly when it's properly installed, so it looks pretty sick IMO. Are you saying that yours became more and more misaligned as time went on though OP?
https://ls1tech.com/forums/appearanc...-new-tips.html
But I have a question guys I got pm'd these will slide right over my 2.5 That I have now so I can just clamp them on or will it just butt up to them?
Sorry I know not sponsor I just need a quick reply http://m.summitracing.com/parts/PYE-PVD10
