are aftermarket gauges worth it?
Old Mar 9, 2012 | 11:43 AM
evilz99's Avatar
Default are aftermarket gauges worth it?
I have autometer water temp, and oil press electronic gauges and see it is a pita to install on these cars. Is the stock cluster really inaccurate enough to be worth installing these? I dont go crazy in my car its just a cruiser that sees some "spirited" driving from time to time and the occasional race.
Old Mar 9, 2012 | 12:12 PM
cchesser1990's Avatar
def worth installing aftermarket gauges. its a fact theyre proven to add 50+ whp
Old Mar 9, 2012 | 12:54 PM
armyboyatc's Avatar
Well it all depends on what you want. The stock gauges will not be as accurate as aftermarket gauges. Do you NEED them? Probably not. If you WANT them then do it.
Old Mar 9, 2012 | 12:58 PM
LS1-450's Avatar
It's a matter of preference. Aftermarket oil pressure gauges are true pressure indicators where many times stock gauges are just go, no go, dummy gauges, where minimal pressure will allow the gauge to read normal. Don't need the water temp. There is the dash gauge + a separate temp indictor to the PCM.
Also, depends on mods. For example; w/forced induction; I would use all aftermarket gauges.
Old Mar 9, 2012 | 04:26 PM
Starz T/A 17's Avatar
IMO I would only spend the time and money putting in aftermarket gauges if I modded the internal engine to the point where I would want to monitor it more closely (big cam, heads, etc). IMO with a stock bolt on car the stock gauges will let me know if there is anything wrong.
Old Mar 10, 2012 | 08:27 AM
evilz99's Avatar
thanks a lot for alot the reall responses. You guys basically confirmed what I was thinking. chesser you sound like a douche stay in delaware
Old Mar 10, 2012 | 08:45 AM
blackls1ta00's Avatar
i def think factory guages are off esp water temp.
Old Mar 10, 2012 | 03:17 PM
gMAG's Avatar
If you're used to seeing your gauges respond in a certain manner....as an example, if your stock oil press gauge usually sits right in the middle.... and it is responding differently than you're used to seeing, that there is cause to pay closer attention.
This also applies to any other stock gauge.
In a similar way, you can buy aftermarket and apply the same principle.
For this reason, I wouldn't bother with aftermarket.
Old Mar 10, 2012 | 07:03 PM
67RSCamaroVette's Avatar
Tach is the only aftermarket gauge I'd use.. factory one just can't keep up.
Old Mar 10, 2012 | 10:31 PM
VandykeT/A's Avatar
My aftermarket temp gauge is showing around 150-160 when my in dash one is at 210. The tach is definately slow. I've hit my limiter (6800) when my stock tach was showing 64-65. The only reason I added gauges was honestly just for the look of having them on the a pillar. After seeing how inaccurate the stock temp gauge is I'm glad I did. After my h/c/i my car started running in the 220-225 range at times. (before was 195) On one instance the temp got slightly higher after running it hard and my check gauges light came on and the stock one started to peg but immediately started going down after I stopped (got caught in construction traffic) but the car never did it again with the stock radiator. The hole time I must have been driving right on the edge. I then swapped in a LT1 radiator and my car usually runs 180 but never goes over 195-200 degrees. For a mild car I wouldn't worry about them but they do look cool lol.
Old Mar 29, 2012 | 11:38 AM
imma_stocker's Avatar
Kinda related question, which factory gauges affect the PCM? While my motor is still out of the car I'm thinking of using the factory sensor locations for my aftermarket gauges. Will the car care if the coolant temp sensor and oil pressure sensor aren't there?
02 Camaro if it matters...
Old Mar 29, 2012 | 11:53 PM
GiggleJuiced_SS's Avatar
id agree with an aftermarket oil pressure and tach gauges. if you use any power adders, id buy a good wideband. just simple gauges, not 10 scattered everywhere so it looks ricey.
Old Mar 30, 2012 | 05:54 AM
senicalj4579's Avatar
Get an aeroforce gauge. Iv had one for 2 years I love it. Just plugs into your obd and mount the gauge on the side. It reads more things than you can imagine.
Old Mar 30, 2012 | 10:50 AM
Detoxx03's Avatar
I had a gauge pod with automated gauges in my trans am and they worked well and I like them a lot. With this car I don't want a pod and I'll pass on all those different gauges so if I do one it will be the Aeroforce Interceptor and that's it.
Old Apr 8, 2012 | 11:12 PM
1qwk00ss's Avatar
Old Apr 9, 2012 | 10:22 AM
88gtman's Avatar
Just get a ScanGuage II. I got one an love it. Takes less than 2 minutes to install and gets you nearly 40 gauges that all read directly from the computer. It will display up to 4 gauges at once. I have one and am very happy with it. They are less than $200.
Here is the site.
Old May 5, 2012 | 02:49 PM
Vexzer's Avatar
Here is the site.
That's cool & at a great price, but no way to connect WB02 -Damn!
