Pictures of Wegner Automotive Research's GMPP LS1 intake & Distributor drive
Recently, I was at Wegner Automotive Research and saw their flyer on the WAR's GMPP LS1 intake and supporting componets. I'll post up more info later.
BTW-WAR builds or freshens ~200 or so NASCAR (Busch & Truck), circle track & dirt track racing engines a year.
Yes, I'll get it posted soon. Basically, ~520+ flywheel hp with ported LS6 heads & LS6 cam. The torque peak moves up to ~
5,200+ rpm. Part of the power will depend on the intake porting done. WAR designed the intake with material to allow for proper port matching.
There are several ways to use the intake.
With the front adapter and WAR ignition system. Can also use mechanical fuel pump and WAR has a water pump too & crank trigger.
Factory wiring harness & PCM, add MAP sensor to the intake. Use elbow like the 5.0 guys either with or without MAF ie speed density tuning could be used.
Aftermarket set up like Electromotive TEC3 control system for the engine & intake.
I'll get more info posted tomorrow.
automotive, block, cylinder, distribator, distributor, generation, gmpp, heads, intake, ls1, manifold, research, truck, war, wegner
