Rewiring o2 sensors/harness. Could use some help...
I need rewire my front o2 sensors. Years ago, I cut them to lengthen the wires for LTs. I want to get this build right, so it is time to fix this. What are my options to get a proper/accurate signal again?
That is a brilliant solution. I saw it the other day. However, mine are already cut and spliced (fucked). What I am looking for is a solution to the fact that I basically have 4 cut wires and need to feed them into a harness.
Could it be as simple as taking the good end of the wires and a harness (at the o2 side) and wiring the wire ends into the plug?
Which wires are cut? Your front o2 leads? or rear? or both?
I assumed you had only spliced the wires in the front, in which case that would be an easy fix. Just re-wire the pcm to utilize the rear harness.
It has been so long ago that I would have to get under the car to even see what I did with the rear sensors. Chances are I cut them, it was probably 10 years ago. However, if they still exist, then that would work really well. The front were cut before the plug.
This is the direction I am leaning (assuming the rears are not intact).
Thanks for the input!
