ARH 1 7/8" install
Old Mar 25, 2012 | 10:35 PM
67SS&99SS's Avatar
Question ARH 1 7/8" install
I plan to install a set of ARH 1 7/8 on my 6 speed car this weekend, and wanted to know if there are any special methods for putting these in. I've installed 3 sets of headers before, including the ones on my automatic car, but they were all 1 3/4 and I had the usage of a lift to do so. This time I am going to try to do this on jack stands. How high will I need to get the car in the air to put these on? When I put my 1 3/4" headers on my automatic car, I didn't have to remove the starter, oil filter, drain plug or the boss above the oil filter. I didn't have to loosen the steering linkage either. They just went right into place. I've read numerous threads about the great fit and finish of these headers but none really went into detail about the install process.
Old Mar 25, 2012 | 10:39 PM
JUSTINSWS6's Avatar
They should go in nice ive heard good things about them. My kooks 1 7/8 went in fine.
Old Mar 25, 2012 | 11:13 PM
BennyB's Avatar
Get the car as high as you can for the passenger side header. I used a jack with 3 2x4's stacked. Let's just say it felt really unsafe, but got the job done. On my 1 7/8 headers I had to take out the through bolt on the motor mount for the driver side and remove the oil boss above the filter. It wasn't bad. I should also mention I didn't use arh's, but hear nothing but good things on fitment and performance so you will probably get even better luck
Old Mar 26, 2012 | 12:05 AM
tillery's Avatar
I disconnected the steering shaft to make easier and oil filter. The passenger side went in easy. I like ARHs over any others. The give a little more ground clearance and are thicker. So they do absorb more valvetrain noise.
Old Mar 26, 2012 | 11:32 AM
hdtp ws6 formula's Avatar
Mine went in with no problems. Just go ahead and pull the steering shaft for a little more room on the drivers side.
Old Mar 26, 2012 | 11:40 AM
ZTwentyAteU's Avatar
mine slid right in
Old Mar 26, 2012 | 11:54 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
This is speaking from installing TSP 1 7/8" headers, but I only needed 17 1/2" between the bottom of the K and the garage floor. Jackstands and a single piece of 2x4 got me the heighth I needed.
Old Mar 26, 2012 | 08:06 PM
67SS&99SS's Avatar
Thanks for the info everyone.
I do not plan on changing motor mounts at the time of my install. Is any grinding necessary on the k member for header tube clearance? I had to do this with my jet hots. Also, do I need to consider purchasing a mufflex y pipe brace to keep the y-pipe from hitting the floor pan? I didn't need one for my automatic car but it has a custom fabbed Y. I know the ARH y is one of the best fitting y-pipes out there. Anybody got any pics of the clearance when installed on their car? I don't want to change motor mounts because I drive the car everyday and I've heard some issues with some people having vibrations transmitted through the steering column and into the wheel with poly motor mounts.
Old Mar 26, 2012 | 08:34 PM
jbridwelltransam's Avatar
I'm with you on the motor mount boat. If anything I might replace them with stock rubber ones.
Old Mar 26, 2012 | 08:53 PM
joe77's Avatar
If it helps at all I daily drive with poly motor mounts and tranny mounts, the motor i barely felt at all, but I havent been terribly impressed with the transmission mount though.
Old Mar 27, 2012 | 01:43 AM
BennyB's Avatar
I will just say this, with my stock rubber motor mounts one of my primaries was resting on the driver side motor mount pedestal and another primary would rub the k-frame when it sat at idle. If I were you I would at least put in some new factory rubber mounts. Personally I run solid motor mounts and a poly trans mount, but my car is mainly for track and weekend cruises
Old Apr 2, 2012 | 08:27 PM
67SS&99SS's Avatar
Got these installed this weekend. Headers went in very easy. Didn't have to remove the oil filter or steering linkage. Plenty of clearance at the k-member without any grinding too. Hardest thing was getting the y-pipe on. That took about an hour to figure out. Went ahead and upgraded to MSD wires at the time of the install. The bendable boots are great, they allow you to get ample clearance. I got everything buttoned up, changed my oil and noticed a constant drip from the water pump. Ordered one of those with a new t-stat got it installed today. Only thing left is a tune. From what I can tell, the slp dual dual exhaust isn't that much louder with the headers. Its deeper for sure. I'll really be able to tell when I drive it after I get it tuned.
I'm going to have to clean it up under the hood next weekend. Got pretty dirty under there during the swap.
Old Apr 4, 2012 | 07:16 AM
studderin's Avatar
Looks great. I like my set, the slide right up. I think I just have to take off the oil drain bolt once I only had small jackstands
Old Apr 4, 2012 | 02:01 PM
Scott02WS6's Avatar
Looks awesome but out of concern, with your water pump are you certain its not your weep hole? Could be an indication that your wp is about to go out
Old Apr 4, 2012 | 08:48 PM
67SS&99SS's Avatar
I put a brand new one on it Monday along with a new t-stat.
Old Apr 6, 2012 | 11:30 AM
jmilz28's Avatar
Great choice, worth every penny. Get a tune and you gain everywhere with the bigger primaries. The ARH's use the best steel and the fitment is outstanding. 5-10 years from now, you'll be glad you nutted up for the ARHs.
Old Apr 6, 2012 | 11:36 AM
looks awesome man. Where did you get your plug wires?
Old Apr 8, 2012 | 09:07 PM
67SS&99SS's Avatar
I got them from RPM motor sports. https://ls1tech.com/forums/sponsor-s...ale-ended.html
Old May 19, 2013 | 09:53 AM
38DD2436's Avatar
ARH
Old May 19, 2013 | 10:11 AM
user 8373738's Avatar
If you want louder I have a GMMG I would trade for the Duall Dual! LOL
