stock balancer
Old Apr 12, 2012 | 09:14 AM
1lejohn's Avatar
Originally Posted by SippiSpeedhawk
You may have gotten lucky when you tried it but every time you use the old bolt to drive a pulley on you are begging for stripped crank threads.
Buy or build an install tool or you will eventually regret it.
I've been lucky more then once. A Crank install tool threads into the crank also? I have an install tool for older SBC and BBC's
Old Apr 12, 2012 | 11:29 AM
Cstone812's Avatar
I didnt do any research about putting the pulley back on and attempted to pull it on using the old bolt which stripped some threads out of the crank...use a tap to make new threads and bought the universal install tool which the 16mm adapter STILL was too short...so i actually bought a longer 16mm bolt from fastenal and had the head of the bolt cut off and threaded so it would screw into my install tool and it worked like a charm
Old Apr 13, 2012 | 07:20 PM
cajunss's Avatar
Well I ordered the ATI today. Only part I have left to purchase is a convertor and I will be set. Still looking for the flywheel holding tool J-42386-A . Checked on ebay but they are asking a freaking 100 bucks for it. Anyone know where I can get one cheaper or even rent one?
Old Apr 13, 2012 | 07:26 PM
salemetro's Avatar
Originally Posted by cajunss
Well I ordered the ATI today.....
Way to go! You won't regret it.
Old Apr 13, 2012 | 07:37 PM
cajunss's Avatar
[QUOTE=salemetro;16195351]Way to go! You won't regret it.[/QUOTE
For the cost of it I hope not, LOL
Old Apr 13, 2012 | 10:41 PM
LS6Vette's Avatar
I think there are ways to hold a FW without the tool, but I do not have one for you.
Anyone?
Old Apr 14, 2012 | 04:19 PM
1lejohn's Avatar
If the trans is out u can put a punch or screw driver in 1 of the flex plate holes. You can make a stop and bolt it in one of the starter bolt holes.
Old Apr 14, 2012 | 04:22 PM
1lejohn's Avatar
I'm thinking I bought a new bolt and never stretched it. I use it to snug up the balc. I then use the ARP bolt to torque it on the crank. The problem with the old bolts are that the threads are pulled(torque to yield)
Old Apr 14, 2012 | 07:34 PM
fastazzls1's Avatar
i would buy the kent more tool it will save you so much cussing and fussing lol i liberated one from the gm dealer i work at
Old Apr 15, 2012 | 10:30 AM
Gray86hatch's Avatar
I cut up a piece of flexplate. Wedge it up in the bell
Tim
