Passanger side back spark plug?
Old Mar 24, 2004 | 05:21 PM
beardWS6's Avatar
Default Passanger side back spark plug?
How in the world do you change the right rear plug. It is deep under everything. Do you have to pull the front tire off or what? I would be thankful for any help!
Old Mar 24, 2004 | 05:37 PM
Raise's Avatar
no...u dont have to take the tire off. u just need to try to fit a wratchet in there with a good extension and just wing it man....there aint no science to it...its a b**ch!!!
Old Mar 24, 2004 | 05:41 PM
Hardtop00SS's Avatar
I changed mine under the car, it was a lot easier for me, but I also have LT's. Just take your time man, like 35th Z said, it's a bi**h!
Old Mar 24, 2004 | 05:50 PM
Tranzor's Avatar
Get it from the bottom... took just a few minutes for me that way. #6 was the b!tch for me, not #8!
Old Mar 24, 2004 | 05:58 PM
SUX2BU's Avatar
i never understood why people bitch about plugs so much. all you have to do is pull off the coil packs on the pass side and you should be able to change them and have the car running in under ten min, headers or no headers it doesn't make a difference.
Old Mar 24, 2004 | 07:19 PM
JBIRD02's Avatar
I agree, just unbolt the coil pack rail, carefully slide it up on top of the intake, and you've got room. As far as getting to it, its pretty tight so put the plug socket on first, then the extension, then the ratchet. Hope this helps
Old Mar 24, 2004 | 07:29 PM
Dueledaily's Avatar
Default Under
Coil packs or no coil packs, under the car is the way to go!!!
Old Mar 24, 2004 | 10:48 PM
Raise's Avatar
yes sir...definitely under the car......u can see a lot better under there too!!!
Old Mar 24, 2004 | 10:58 PM
Nice4thgenZ's Avatar
yup same here...
Old Mar 24, 2004 | 11:00 PM
Cheatin' Chad's Avatar
You must have small hands. I had to have my sister in law get the 1/4in ratchet w/ 3/8ths adapter and plug socket on the plug for me and then actuate the ratchet with my index finger to get it moving. With the coils off I could with some finagling get a 3/8ths w/socket on and get it out. It most certainly took me longer than 10 minutes and I was laying on the motor while I did it.
Old Mar 25, 2004 | 02:18 AM
deznuttzz28's Avatar
i jack my car up and change it from there. sometimes i get mad cuz my arm won't fit. i asked my neighbor to reach it for me cuz he has some skinny ole arms. but once u get that done everything else will flow smoothly
Old Mar 25, 2004 | 03:41 AM
35th SS's Avatar
I concur.did it this way ever since.no problem here.pulled and checked all my plugs after a big dose of n20 passes.
Old Mar 25, 2004 | 11:57 AM
i just got done putting plugs in my ****, took about 15 minutes total... and i have a 98
all i do is take off the #8 and #6 coil packs and go at it.. on the #8 plug i use a 3/8 ratchet, 19mm socket (on the back of a spark plug socket)...
then the rest i use a 3" ext. with a spark plug socket
Old Mar 25, 2004 | 01:15 PM
wicked 98z's Avatar
Thats what ive always done
