Please Quick Help TRAP DOOR METHOD
Old Apr 6, 2012 | 01:42 PM
01ssreda4's Avatar
No need for a hinge just cut it 3 sided and peel it back. I'll have a pic posted shortly.
Old Apr 6, 2012 | 03:57 PM
01ssreda4's Avatar
The cut, sides and rear, front side left intact.
Panel pulled back down. Two small strips of sheet metal riveted in-place to hold the panel flat and then sealed with foil tape for AC ducting. The sheet metal pieces swivel out of the way to let the panel come back up for quick access.
Thank Hilton for the idea, he did it.
Old Apr 6, 2012 | 05:23 PM
99Bluz28's Avatar
I used rtv and aluminum rivets to secure the small piece of painted sheet metal I used.
Old Apr 7, 2012 | 10:26 AM
US_Army_Z28's Avatar
I used the exact diagram that people have quoted in this post and im gonna be honest itts a pain in the *** with those dimensions. If yyou want a lil more room to work with id go a little larger by a few inches on each side
Old Apr 7, 2012 | 12:39 PM
99Bluz28's Avatar
I'll have to admit, I did have to bend one of the locking arms upward to to get the lock ring up through my trap door cut out since I tried to make mine as small as possible. So if anyone does one as small as mine you might want to consider cutting it about 1/4" lower at the bottom.
Old Apr 9, 2012 | 10:37 AM
needtransam's Avatar
thanks for the pics 01ssreda4 and 99Bluz28 its gives me a really good example on how to do mine
Old Aug 30, 2014 | 05:37 AM
Luracious P's Avatar
Originally Posted by 01ssreda4
Buddy just came over and did mine for me and he cut 3 sides and peeled the panel back. During reassembly he drilled two holes just to the outside of the cut panel and we took 2 pieces of sheet metal and drilled holes in them. He then riveted the sheet metal to the body panel holes. The top riveted pieces will swivel over the panel to hold it down or swivel out of the way quickly to pull the panel up for access. We sealed it with silver foil tape to act as a vapor barrier. Quick and easy process that works very well.
Have any Pics? Of that thanks, know I'm kinda late thanks again
Old Aug 30, 2014 | 08:16 AM
01ssreda4's Avatar
^^^Yeah, they are posted above on this page!
 Michael S. Palmer
Old Sep 2, 2014 | 04:20 AM
Pony Exp.305's Avatar
I saw someone had done nice method in drag tech or fuel injection section. Search
Old Sep 2, 2014 | 04:41 AM
omarrakeen's Avatar
98 is different than 99+ they are NOT the same. make sure not to cut through your wire/lines. i just cut 3 sides 01ssreda4 did and covered it with duct tape. one of the most handy things i ever did. my pump died last week and guess what took my 5 mins to get it out.
