Pics of the 90mm LSX manifold and comments
Old Mar 25, 2004 | 05:35 PM
ITSovr4U's Avatar
Originally Posted by Fireball
$499.00
Its the same as MTI. Nobody had any finished TBs in stock but TPIS had some 90 mm housings which needed the stuff from the OEM TB. Thats the route I went
Well i am glad i paid 649 from MTI for the same thing.
Old Mar 25, 2004 | 05:36 PM
Fireball's Avatar
its cause you have a C5. F-bodies are simpler design
Old Mar 25, 2004 | 05:37 PM
Fireball's Avatar
Originally Posted by WstSidHomE
Any benefits for stock CI motors N/A?
I personally wouldn't go this big unless you have a good set of high-flow heads and a healthy cam. Kinda overkill otherwise
Old Mar 25, 2004 | 07:45 PM
angst911's Avatar
Originally Posted by LS1 Power Plant
I did not use the factory; I used the hex that came with the intake. I believe the two short ones are for the TB linkage bracket. And correct, the other 5 are for your TB. My intake did not come completely assembled; I had two long bolts in the bag. My intake came with two small o ring gaskets (about the size of the rubber above the knock sensors), did yours? I have no idea where those things were to go.
open the bag... it's one big one folded in half... I thought the same thing.. it's the 90MM o-ring for the TB
Old Mar 25, 2004 | 08:05 PM
SStroked 410's Avatar
When are you going to dyno the car now?
How much are you expecting to gain, I would say maybe 8rwhp on a 346
good luck
Old Mar 25, 2004 | 11:19 PM
LS1 Power Plant's Avatar
Ah man, that's what I get for not opening it. Thanks thou.
Old Mar 26, 2004 | 04:46 AM
Fireball's Avatar
good luck
being that I'm a h/c car with a cam over 230 duration at .050
I'm a bit more of an optimist based on LGs results. I've also seen enough evidence that the TB is starting to become a restriction at my power level. I'm guessing 15 or so RWHP gain
Old Mar 26, 2004 | 08:12 AM
CHRISPY's Avatar
Looks great Brian!
I am really interested to see your results, our combos are very similar.
