Wtf ory
Old Mar 30, 2012 | 10:52 PM
FU_I_AM_UltraZ's Avatar
Veteran: Marine Corps
Default Wtf ory
So I ordered a ory from dynomax... had a B*TCH time to install... had to trim an inch of the passenger side so the y pipe collector would fit on driver and passenger side pipe. I called dynomax and jegs... jegs shipped me another set (after buying it so my car wasn't down) and dynomax said that the pipe could've bent during shipment... that was a load of bs... though consider how poorly dynomax packed it...
But the problem with the ory system is the driver side pipe lays right against my floorboard under my seat... smacking it... so i had to spend $50 for header wrap so the clank wasn't so bad... honestly... it looks like they welded the flange on with a wrong angle... there's no way the pipe bent in shipment... NO WAY!!! Anyone else ever have a problem with dynomax?
Old Mar 30, 2012 | 11:23 PM
01transampower's Avatar
I didnt have dynomax but i had the same problem with my tsp ory pipe. Its not the y pipe necissarly. Sometimes the drivers side header just sits closer to the floor board then other headers. Idk if this is do to poly mounts or solids either way. I went through the same thing had to wrap it to get rid of the clank. If it really bugs you you can have the exhaust shop fx it. I have true duals now and the exhaust shop had to make some funky bends to get clearence off my collector.
Old Mar 31, 2012 | 07:06 AM
omarrakeen's Avatar
what he said. it is not the Y pipe its the longtubes\ you car due to the mounts. you can see various results while installing the same set of LTs on different cars even with the same brand mounts...so i wouldnt worry about it.
Old Mar 31, 2012 | 07:25 AM
96lt4c4's Avatar
I have the new TSP S/S ory. Its really nice and well made. I had to work on it a little to get it to fit just right. I do not think any of them are perfect though.
Old Apr 3, 2012 | 08:58 PM
Negative... I DO NOT HAVE LTs on this car.. it's the dynomax ory that bolts to stock exhaust manifolds
Old Apr 4, 2012 | 07:17 AM
omarrakeen's Avatar
oh crap lol i just saw the pic, my bad. in that case i never seen anything like that. good luck with the fix!
Old Apr 29, 2012 | 01:15 AM
I've never had anything like this either... This is my 4th LSX car i've modded and never had this problem... I did put a random tech catted stock y pipe on my sister's ws6... PERFECT FIT!!!
Old May 5, 2012 | 03:13 PM
So the MAC ORY system is installed and fits... dynomax, you guys need to re check the specs of the driver side pipe cause the flange and pipe DO NOT have the right angle. The 2 systems I bought, the driver side pipes DID NOT fit without the pipe sitting against my floorboard and had to spend an additional $50 for header wrap to soften the banging so my car didn't keep retarding and throwing a code.
