crank pulley question
Old Apr 16, 2012 | 02:24 PM
mjs1012's Avatar
Default crank pulley question
I just put my crank pulley on using the install tool and i was wondering if i still need to use the old bolt and torque it down or can i just go ahead and put the new bolt in?
Old Apr 16, 2012 | 04:24 PM
sheaadams86's Avatar
Don't think it really matters, I reused my stock bolt and everythings fine
Old Apr 16, 2012 | 04:33 PM
2000PewterT/A's Avatar
I installed it with the installer tool, then used the old bolt to torque it down, then removed it and installed my Arp bolt. Probably not necessary to do all of these steps but I am picky lol.
Old Apr 16, 2012 | 08:06 PM
mjs1012's Avatar
Is there a sure way to make sure it's on all the way?
Old Apr 16, 2012 | 08:07 PM
mjs1012's Avatar
Without having to torque down the old bolt.
Old Apr 16, 2012 | 08:14 PM
ULTIMATEORANGESS's Avatar
Smile
i remember my instructions saying use your old bolt to get it in place.
Old Apr 16, 2012 | 09:07 PM
joecar's Avatar
Have a careful read of these (I picked 3 from a search):
https://ls1tech.com/forums/generatio...nk-pulley.html
https://ls1tech.com/forums/generatio...y-install.html
Old Apr 17, 2012 | 08:36 PM
mjs1012's Avatar
Thanks but those links didnt really help. i already have the pulley on. I just need to know if i should retorque the old bolt then put the new one in, or can i just go straight to putting the new bolt in?
Old Apr 17, 2012 | 08:41 PM
thegroup's Avatar
+1 here. May be overkill but better safe then sorry
Old Apr 17, 2012 | 09:22 PM
joecar's Avatar
Ah, I misunderstood the thread, sorry...
The GM Service Manual says to use the old bolt in step 3 of a 4 step process
(after using the "tool" to install the balancer, it says to torque the old bolt to 240 ftlb and then remove the old bolt).
Old Apr 17, 2012 | 09:40 PM
dodson55's Avatar
honestly i use the tool to pull the balancer on and then re use the old bolt and impact it on tight i know its not the gm approved way but i have did several and never have a problem
Old Apr 18, 2012 | 05:02 AM
If u want to get technical u can use old bolt to tighten, then remove, then grab a 6in scale, and there's a measurement from crank to inner lip of pulley, it in the chilton book somewhere, forgot what it was
Old Apr 18, 2012 | 06:06 AM
mjs1012's Avatar
Thanks guys. I'll try your method dodson55 just to be on the safer side.
Old Apr 18, 2012 | 06:33 AM
cranny's Avatar
I use a pulley installer then hammer down a new bolt with an impact gun. We've done a bunch of them like this and never had a problem.
