Can bad check values in the A.I.R. system cause these codes:
Old Mar 27, 2004 | 10:42 AM
ACCELR8's Avatar
Default Can bad check values in the A.I.R. system cause these codes:
P0135 - HO2S Heater Circuit Bank 1 Sensor 1
P0155 - Heated Oxygen Sensor Heater Circuit (bank 2, sensor 1)
Thanks,
Jim
Old Mar 28, 2004 | 09:59 AM
ACCELR8's Avatar
anyone?
Old Mar 28, 2004 | 10:13 AM
wrencher's Avatar
wrencher
No not likely to cause heater codes at all...............
Old Mar 28, 2004 | 10:23 AM
ACCELR8's Avatar
Thanks!
Do you have any idea what can cause these codes? I've heard that exhaust leaks can, but I can't find a leak anywhere. It's driving me nuts.
Jim
Old Mar 28, 2004 | 08:07 PM
Mirek's Avatar
I get those same two front 02 sensor codes since I installed my longtubes.
There is a different sensor position and thats what my problem is anyway.
Rear 02 moves to the front position with the lgms.......but the front position is way further downstream. Check all your wires and make sure you do not have any leaks.
Old Mar 28, 2004 | 08:35 PM
Ferocity02's Avatar
Definitly sounds like an O2 sensor issue. I would say take your car to the dealer and get thier opinion, but they wont be happy with the LT's and will try to blame them.
Old Mar 28, 2004 | 08:58 PM
ACCELR8's Avatar
Mirek,
Could you elaborate on your response. I don't understand how the location of the O2 would throw a code. And if it does then how do you resolve the problem? Sorry for sounding stupid, but I had a hard time following your explanation.
Thanks,
jim
Old Mar 28, 2004 | 09:27 PM
rushman's Avatar
My understanding is the os2's are calibrated to run at a certain temperature, when you move them or change the general exhaust flow around them, you change the operating temperature for them a bit.
Old Mar 28, 2004 | 10:10 PM
wrencher's Avatar
wrencher
The PCM is not getting the proper feed back/response time for O2's & sets a code.
It is prolly an O2 problem,on L/T cars some seem to have an appetite for O2's.
