Power steering pump removal/install guide?
Old Mar 27, 2004 | 02:43 PM
Magyver's Avatar
Default Power steering pump removal/install guide?
My pump seems to have a slow leak. The leak screwed up my alternator. Can someone point me to a site that shows how to remove it so I can inspect for leaks. And if anyone knows the price to replace that would be helpful.
Old Mar 27, 2004 | 03:10 PM
Scalpel's Avatar
http://www.ls1howto.com
Old Mar 28, 2004 | 07:37 AM
Magyver's Avatar
Originally Posted by CANNIBAL
I found out how to....to a degree. I need to remove the pulley, so what tool do I use? This would allow me to remove the high pressure line and get the that annoying bolt.
That pic shows how to remove the entire pump, but I need to get the pulley off first to make it some much easier. Does anyone know what tool to put in?
I am going to replace the seals.
Power Steering Seal Kit
Old Mar 29, 2004 | 11:46 AM
WILWAXU's Avatar
There are 2 13mm bolts that hold the pump to that bracket behind the pulley, IMO they are much easier to get to.
Old Apr 3, 2004 | 03:26 PM
Magyver's Avatar
Yeah I removed the pump itself off of the braket. Took the pulley off witha puller I borrowed from autozone.
Old Apr 3, 2004 | 04:34 PM
Scalpel's Avatar
I couldn't get that Autozone puller to work.
Old Apr 3, 2004 | 08:25 PM
WILWAXU's Avatar
umm.. if you take out the 2 bolts I'm talking about, you do not have to remove the pulley.
Old Apr 3, 2004 | 08:38 PM
Zero2Sixty's Avatar
My autozone pulley work perfect today. Also, Wilwaxu is correct - if you can get a wrench behind the pulley you can remove the pump without having to remove the pulley.
Old Apr 3, 2004 | 10:38 PM
Mike K.'s Avatar
It is possible to get the wrench back there. I had to do it when tearing down my motor and while you can only get in a small turn it is possible to do it and IMO probably easier than removing the pulley.
Old Apr 4, 2004 | 09:57 AM
WILWAXU's Avatar
Gear wrenches are your friends
Old Apr 5, 2004 | 08:14 AM
Magyver's Avatar
You can work the 3 bolts holding the entire bracket if you can't get the pulley off or if you get the pulley off go for the bolts in the front to take the pump off the bracket. The puller was a little confusing at first but I got it to work. I actually PMed someone else who used it and he told me what to do.
Old Aug 26, 2018 | 01:23 PM
cornfedlsx's Avatar
how do you get it back on then? Wouldn’t it be terribly difficult to thread those bolts back in with the pulley in the way ?
Old Aug 26, 2018 | 03:38 PM
You DO know you're replying to a 14-year old thread, right?
Old Aug 26, 2018 | 09:29 PM
cornfedlsx's Avatar
didnt even realize lol oops
Old Mar 12, 2022 | 01:46 AM
JustinW's Avatar
Then there's me wanting more info from an 18 year old thread............ I'm used to the bolt type puller and have no clue what size of this kind of puller i need or where these 3 bolts are. Haven't looked yet as its 12am now but if your still I'd appreciate it
Old Mar 12, 2022 | 02:11 AM
Well, nothing new in the last 4 years since replying last, so don't get your hopes up....
Old Mar 12, 2022 | 03:17 AM
QwkTrip's Avatar
It's a special kind of pulley puller that grips the groove on the snout of the pulley. I think you can rent it from AutoZone, OEM Tools 27031. The same tool can press the pulley back on.
