Fuel Lines
I've heard about AN fittings but other than that I don't know much about these type setups.
What type of line do I use to connect the front of the rails? Are they available at parts houses or are these something you need to order from a company? Basically any info on how these need to be connected would be very helpful.
Thanks,
Brandon
(x2) 3/8" NPT -> 8AN 90 degree fitting
about 12 inches of 8AN steel braided line.
As soon as you are done, it should look something like this:
Is it possible to run a hard line between the two fittings? I'm most likely going to be painting this and I think a hardline would be easier to paint.
Thanks,
Brandon
