sign of a clogged fuel filter???
I am having a similiar problem. I have a '99 z28, stalled with no warning in traffic, doesn't idle without giving constant gas, running extremely rough and sounds like a tractor, has white exhaust, it is getting fuel at rail, showing P0101 code. Cleaned K&N Filter as well as cleaned stock MAF sensor, reset code, started again, still the same. Ran it without MAF sensor and it still ran rough. Does anyone have any insight or suggestions on what to test next?
OMG! A q-tip!!!??? You remove from housing and just spray it. The only other thing I can think of guys is the idle air control valve...
