Sudden drop in voltage from 14 to 11
Some shops use cheap Chinese rectifier assemblies with 45amp diodes instead of the factory 55amp spec, they run for a while and then pop. Depending on what your shop modified to make it output more power, it could be that the diodes aren't up to the load.
I'd pull it off the car and take it back to the shop for teardown.
